Old October 13th, 2007   #1 (permalink)
Randy's Avatar
Default Lightscape & Win x64 - It's working
Hi lightscape friends,
already posted this on the vray-board, but since this seems to be the last place for lightscape hardliners (like seismograph said ) - I'll post the solution here.
The installer will complain about missing 16/8bit system ... and quit.
Install LS3.2 on a 32bit machine (client or use vmware), start it and enter your personal serial number and activation code. Copy the installation folder to a path of your choice on your x64 machine.
Now export two reg-entries from the 32bit machine: regedit, (on the left pane, right click - export.)
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape]
and
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape]
The first key contains your registration data and should be fine. The second key needs a bit tweaking.
Change every reg-path from:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\3. 2\Profile]
to
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\L ightscape\3.2\Profile]
(You have to add the \Wow6432Node\). Make sure the installation path in the reg entry is ok (D:\Program Files\Lightscape\...)
Copy the two reg entries to your x64 machine and add them to the registry (double click), dont forget to backup your registry before).
Start Lightscape and enjoy. If its crashing, (only happens in few cases with vista x64) delete your "nvogl32.dll" in the windows\SysWOW64 folder and replace it with a older winxp x64 "nvogl32.dll".
Randy is offline
Old October 13th, 2007   #2 (permalink)
Default Re: Lightscape & Win x64 - It's working
Is this a joke?!?!
Beeeee!
del82 is offline
Old October 13th, 2007   #3 (permalink)
I always believed in my heart this is possible, even tried something similar (did not know for "wow key").
Did somebody tried it yet?
LS strikes back again!!!
okmijun is offline
Old October 13th, 2007   #4 (permalink)
Randy's Avatar
No, its not a joke:
its Vista Ultimate x64 with LS3.2, no compatibility mode or other tricks
Randy is offline
Old October 13th, 2007   #5 (permalink)
My God!!
Its like a new version of Lightscape has come out
Beeeee!
del82 is offline
Old October 13th, 2007   #6 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
I did try Lightscape on my new XP-64 machine and it did not work. I'm glad to know its possible. Thank you for your efforts on this!
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old October 13th, 2007   #7 (permalink)
Randy's Avatar
Why its not working? Do you see error messages? It worked for me on Win2003 x64 and Vista x64.
-Install LS on a 32bit machine (vmware+w2k worked for me)
-Enter your registration data and activation
-Copy the installed LS program folder to your x64 program folder ("program files x86", not to "program files", because LS ist still a 32bit application
-On your 32bit system export the two LS reg entries (see post above)
-Edit them (notepad) on your new x64 machine add the "Wow6432Node" and correct the installation path
-Add them to your registry (click)
-Start LS
Attached my registry key, containing the new reg paths. Just edit your installation path inside of it.
http://www.eldaco.net/upload/vray/ls-localmachine64.zip
Good luck.
Randy is offline
Old October 13th, 2007   #8 (permalink)
How about instaling SP1?
Did you try that?
Cam it be migrating?
okmijun is offline
Old October 13th, 2007   #9 (permalink)
Randy's Avatar
You mean Lightscape SP1? No Problem, because all the informations are stored in the registry. Installation went just fine.
The screenshot above is LS 3.2 SP1 - thanks to seismograph for the SP1.
Randy is offline
Old October 14th, 2007   #10 (permalink)
So, you instaled SP1 on Vista or on XP and migrate all installation folder to Vista/ XP x64?
okmijun is offline
Lightscape Scripts for max molson Scripts 10 July 25th, 2008 06:39 AM
installing win xp pro x64 on MacPro mesht Hardware and Technical Discusions 8 March 18th, 2007 09:46 PM
(Old Topic) Lightscape versus XP or ? dbillo Lightscape 27 April 8th, 2005 04:53 PM
Graphic card for lightscape. Lidia Lightscape 13 March 24th, 2005 01:02 PM
lightscape to be retired stephen gilbert Lightscape 14 December 22nd, 2002 11:11 AM
