Go Back   CGarchitect.com > 3D SOFTWARE > Maya
Maya Alias
Old October 15th, 2007   #1 (permalink)
Default how do i make a decent glass shader
HI,
I am using maya and am struggling with a decent glass shader.
Its going to be used for the windows on the house i am making.
I have a sphere with a sky texture mapped to it which is visible in reflections and refractions.
I have a phong shader applied with reflectivity turned up high and transparency turned right up. So the curtains can be seen through
To be honest the settings make the render look rubbish, and I have no idea what i need to do.
Any help is much appreciated!!
thanks
karldavies is offline
Old October 16th, 2007   #2 (permalink)
shaneis's Avatar
Default Re: how do i make a decent glass shader
You could try the mia_material if you have Maya 8.5 (hit the preset button and choose "glass_pane"), or otherwise make a dielectric material and adjust it as you see fit. Each of which have the correct IoR - 1.5(ish). If you're getting blacks with the dielectric, tick the checkbox "ignore normals" and you're away. NOTE: if you are using G.I., you'll have to create another node - "dielectric_material_photon" from the "Photonic Materials" menu. Simply middle click and drag it onto the original dielectric material's "shader group" node (dielectric_material1SG) and choose "default" as the connection option. That way ensures that photns will react properly with the material. Similarly, if you are using the mia_material, you'll have to connect the photnic attributes - again, middle click and drag the material node onto the material's shading group node and select "default". Now the material is connected for photons and shadows.
Another note, hit this site
http://mentalraytips.blogspot.com/
Zap's kind of up with things for the MR4M shaders...considering he writes for them!
All the best,
Shane
shaneis is offline
Old October 16th, 2007   #3 (permalink)
hi, i used the mia_material with the glass pane setting.
However its just coming out transparent. with no reflections.
Also i cant seem to get the sky i have mapped to a sphere to render in the reflections...
What do i need to do so i can get some nice clouds appearing in the window.
Old October 19th, 2007   #4 (permalink)
shaneis's Avatar
Check the RenderStats for the sphere - in it's attribute editor. Make sure that reflections are on. Secondly, make sure your raytracing settings are up high enough to allow the rays to make enough bounces. A good rule of thumb for glass in maya is to use reflection/ refraction =6, trace depth =12, and you can start with shadows = 2. All in your RenderSetings. Make sure each raytracing light has it's shadow rays equal to your renderSettings shadows (in this case, 2). You should also check that the sphere's normals are facing the rightway, for an envSphere, they should all be pointing inwards. If not, in polys menus, Normals>Reverse.
Give that a blast and post your results. Much easier to spot render problems with an image.
shaneis is offline
mental ray glass material smr_VIZ Autodesk VIZ 2 October 7th, 2007 09:36 PM
mental ray: glass material smr_VIZ Mental Ray 1 September 17th, 2007 05:04 PM
Glass Help tbny Work in Progress (WIP) 4 August 8th, 2007 09:03 PM
semi transpaent glass or claudioarchi Modo 4 July 16th, 2007 08:30 AM
exterior scene..help with glass drvox VRay Render 3 December 21st, 2006 12:07 PM
