Name: ahmon williams |
About to build a small home render farm. I have just built one render node and before build more I would like to know:
Will there be a noticeable decrease in render times using a 1000Mbps (Gigabit)LAN setup over the standard 100mbps I am using now? I ask this because I did a test rendering with my workstation consisting of 4 cores and the time was 6:48 when I added the render node to it, total of 6 cores, the time went down to 5:39. That decrease of 1 minute for every 7 minutes of render time looks ok to me and with the additions of a few more nodes, the projects that would have taken an hour or very much more will go down quite far. So I don't want to waste the money on changing my network and increasing the price of the render nodes (even though they will only cost about $150 each) if the time decrease is not going to be noticeable. Would you? |
Name: Dan Chasteen |
The lager your scenes the more of an impact a gigbit LAN will have on lowering your render times. If you distribute rendering an image that takes an hour to render then the gigbit LAN will have almost no impact.
| V-Ray Version 1.5 Officially Released! | Jeff Mottle | CGA News | 1 | August 9th, 2007 05:48 AM |
| Vray animation render problem | field3d | VRay Render | 4 | January 16th, 2007 12:34 AM |
| Trying to get better render times. | Neelu | VRay Render | 12 | July 4th, 2006 10:30 AM |
| render times | mzex | VRay Render | 2 | December 10th, 2005 10:10 AM |
