Old October 21st, 2007   #1 (permalink)
Pakistan
Default Vray proxy with vraydisplacement...
I am creating a scene which includes a lot of grass...i wanted to use vraydisplacement to create grass and convert it to vray proxy...
prolem is that vray proxy only works with static geometry...whereas displacement is dynamic(i.e. calculated on render time)...
if i export any object with vraydisplacement modifier to vrmesh...and then use its proxy...the proxy object becomes totally flat..it doesnt retain its displacement...there is no way to collapse vraydisplacement to make it permanent...
it is the way vray proxy is supposed to work...but i need it the other way around...
is there anything which can convert vraydisplacement to static geometry before render???
or Is there any other workaround???
thanks
baba147 is offline
Old October 21st, 2007   #2 (permalink)
dra3's Avatar
Philippines  Send a message via Yahoo to dra3 Send a message via Skype™ to dra3
Default Re: Vray proxy with vraydisplacement...
try regular displacement,,,so displacement will be in your material not in the object...thats what i do...
Inspiration is what drives me most,,,
dra3 is offline
Old October 21st, 2007   #3 (permalink)
dagor's Avatar
Russian Federation Send a message via ICQ to dagor Send a message via MSN to dagor Send a message via Skype™ to dagor
may be i`m wrong, but proxy work with dynamic geo very well!
can you show where did you know that proxy use statyc (help or forum link)?
dagor is offline
Old October 21st, 2007   #4 (permalink)
Pakistan
I dont remember where i read that...but it is whats happening to me...
i apply a vraydisplacement modifier on an object...the displacement isnt applied in viewport...it is applied at render time...so if i export the object as vrmesh then it is exported as it is in viewport(which is undisplaced)...vray mesh export simply ignores the displacement modifier...
also it is written in vray help that vraydisplacement modifier has no effect on vrayproxy objects...
The only solution i have found is to use max's displace modifier on a high polygon object(which applies displacement in viewport)...then we can collapse the modifier stack and export the displaced object as vrmesh.
have you tried using vrayproxy with vrayfur and vray displacement???
both doesnt work with vrayproxy for me...
baba147 is offline
Old October 21st, 2007   #5 (permalink)
Chad Warner's Avatar
What about using the displacement map in the VrayMtl? That should work on the proxy.
Chad Warner is offline
Vray - Proxy objects and Distrubted Rendering? JamesTaylor VRay Render 18 1 Week Ago 12:25 PM
Vray Proxy with Material SunGlare VRay Render 14 May 13th, 2008 09:22 AM
Vray proxy... arkitech2 VRay Render 3 December 9th, 2006 01:42 AM
Vray Proxy model simplification Script archiviz VRay Render 3 August 6th, 2006 01:23 PM
optimize a model...vray proxy??? akzit VRay Render 1 February 17th, 2006 10:25 AM
