Name: Christian Robberstad |
Hi!
I'm having a problem exporting and importing files from autocad to 3ds max. The file imports fine, but the spline that looked nice and smooth in autocad turns out jagged in 3ds max. Also, some of the points seem to be out of place compared to autocad. I turn on smooth when importing, but that doesn't help anything. What am I doing wrong? |
#3 (permalink) | |
Name: Paul Wild |
Just tried it, but the line is the same... Should I change some of the settings in the import dialog? Could it be that the dwg file is a spline or polyline? Or should I convert it to something else in Autocad?
In the Geometry part of the import options you can change the 'curve steps' to a higher value which will give your curve more facets, but there is no way to import a polyline with curved parts and keep the true curve as far as I know.
Name: Fernando Tella |
Move the drawing to 0,0,0 coordinates before exporting. It makes it more precise.
www.ftella.com |
Thank you so much!
That actually helped! Weird thing that it made such a big difference moving the polyline! Been messing around for 9 hours straight now, so I was about to give up... Thanks again! |
Name: valeria prosseda |
Well I have this problem and I have not idea what can I do. The polylines in AutoCAD are fine, but in Max they are not. I have read here that there is not much to do. That is true?
Name: Brian Freed |
That looks a LOT like what happens with the "Import AutoCAD drawing command." (Instead of "LEGACY" AutoCAD mentioned above).
Are you working near 0,0, and using the "legacy" import and still getting that problem? |
| 3ds Max 8 Service Pack 1 is out | theqball | 3ds Max | 4 | August 10th, 2006 07:12 AM |
| 3ds max 8 won't launch on Opteron/WinXP64 render nodes | ShaunDon | Hardware and Technical Discusions | 8 | July 8th, 2006 09:16 PM |
| MAX Script for replacing geometry in an imported DWG file? | jonssonhenrik | Scripts | 1 | June 26th, 2006 07:32 AM |
| Importing CAD models into 3ds Max 7 | bover | 3ds Max | 1 | October 10th, 2005 10:51 PM |
| CAD to MAX issue......snaps problem | salf | 3ds Max | 6 | June 9th, 2005 12:43 PM |
