| 3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum. |
Name: James Burrell |
Hi all!
Long time reader of the forums. Some great info on here. I just purchased the Onyx GardenSuite Superbundle for max 9. I've been getting my teeth into it but i've hit a snag. In the tutorial regarding UV mapping leaves on any tree it says to check the uv box in the Leaf row, then select the Sub-objects button. Thats all fine but it then says to "Set Number of s-objects red slider to 1" Here is the problem. I cant set the number. I've clicked here there and everywhere, typed in values, hit + and - but no slider or values appear for me... I will contact Onyxtree if noone here can give me a hand but any information is much appreciated. Cheers, James |
Name: travis schmiesing |
you should be able to put your cursor o the very left edge of the slider box, and slide it to the right. you need to be within a pixel or 2 of the left edge of the box.
travis schmiesing |
#7 (permalink) | |
Name: Michael Mundy |
Yes, I went there already... That's how I knew I had to BUY the software! I've been using it for about a year now. Most of the time, I don't map any leaf textures to the trees. I pick a tree that has the diamond shaped leaves. I have used them as V-Ray proxy trees with much success. I really like the vertex-color method of coloring the leaves, but I've also tried assigning a solid dark green color to some of the trees, and a slightly lighter green to other trees, etc. This simulated a variety of species. I've attached a small rendering. |
Ah. hehe i didnt know you'd bought it.
That image looks great. Ill post an image im working on soon. The only thing is my shots are a little bit too close to get away with the standard shaped leaves. I've got a pretty nifty idea for a kind of gradient mapped tree so the leaves get more red the higher up on the tree they are. Im going to have a go at it soon so ill post my results then. Cheers! |
| Computer Problem? Need Help? Check Here First! | Greg Hess | Hardware and Technical Discusions | 7 | August 22nd, 2008 05:38 PM |
| nurbs problem?? | to_po | 3ds Max | 1 | August 9th, 2007 02:06 PM |
| New System...Small Problem | camby | Hardware and Technical Discusions | 3 | January 12th, 2004 02:13 AM |
| Video Card problem? | Jeff's Friend | Hardware and Technical Discusions | 12 | September 11th, 2003 05:33 AM |
| Another Small Annoying Problem (A.S.A.P): Trees | cgarchist | Autodesk VIZ | 1 | August 7th, 2003 08:51 AM |
