Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old October 26th, 2007   #1 (permalink)
Default Calculating Final Gather
Is there a script out there that automates the task of calculation final gather.
I'm about to send a 360 frame animation path where all 360 frames need to be calculated - instead of doing this one at a time is there a script where you can specify the frames that need calculation and send it all at once?
Thanks in advance!
cferman is offline
Old October 27th, 2007   #2 (permalink)
Justin Hunt's Avatar
Default Re: Calculating Final Gather
render off the animation, set to every nth frame. Saving the FG to disk. Rerender the animation with every frame. Freeze the FG and there you go
Very easy and even better when done through backburner. just submit each as separate jobs, making the full render dependant on the first. Once the FG animation is calculated the final will start automatically. Freeing you up do go have a beer
JHV
Justin Hunt is offline
mental ray animation-final gather sstamfb 3ds Max 4 October 16th, 2007 05:59 AM
Mental Ray, final gather and bucket artifacts AJLynn 3ds Max 10 June 20th, 2005 09:03 AM
Mental Ray / Final Gather / Buckets problem Ras Autodesk VIZ 12 April 29th, 2005 03:35 PM
MR Skylight and Final Gather nisus 3ds Max 6 February 3rd, 2005 01:43 AM
MR + FG: How to save a Final Gathering Map? nisus 3ds Max 3 June 15th, 2004 07:26 AM
