3ds Max Autodesk 3ds Max
Old October 29th, 2007   #1 (permalink)
Name: Nigel Kirkpatrick
Northern Ireland
Default anyone ever get endlessly expanding files?
Last couple of jobs i've worked on now have had files that just grow and grow even though i'm not adding to the model. I've tried merging all into a clean file and it drops from 110 meg to 70 meg but it instantly starts to creep back up with every autobak save or file save.
Boing is offline
Old October 29th, 2007   #2 (permalink)
rotten42's Avatar
Default Re: anyone ever get endlessly expanding files?
what program?
Mental Health is over-rated
rotten42 is offline
Old October 29th, 2007   #3 (permalink)
Northern Ireland
sorry, Max 9 sp2 with vray.
Boing is offline
Old October 29th, 2007   #4 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
It could be the old file bloat bug. Try this:
1. File>Xref Objects (open and close the dialog)
2. File>Xref Scene (open and close the dialog)
3. Type gc() in the pink edit box in the lower left corner of the workspace, then hit enter. In the white feedback edit box, you'll see a number.
4. Save the file and see if the size changed.
I have had this issue in the past (going all the way back to Max 6) and had noticed that it occurred fairly regularly with instanced lights. I have not had the problem since using fryrender, which requires that you apply an emitter material to an object rather than using actual light objects.
- Fran
Fran is offline
Old October 29th, 2007   #5 (permalink)
dinhtuan's Avatar
Viet Nam Send a message via ICQ to dinhtuan Send a message via Yahoo to dinhtuan Send a message via Skype™ to dinhtuan
I have 500mb max 9+Vray file and when I ease all object and save it still 500mb . To clean that file I have to switch renderer back to scanline - hide all object(scanline can not render Vray material) and hit render - Save and the size drop to 80mb . Have no idea for this because this issue was in max6 and fixed in max 7 like Fran said .
Let try this.
BR
http://www.vnimation.com/
dinhtuan is offline
Old October 30th, 2007   #6 (permalink)
Northern Ireland
Thanks for the replies.
i tried both of those but niether worked, the gc number didn't increase and after scanline the file came down from 107 024kb to 106 998kb.....
Fran did you find that breaking an instanced light (making them all unique) fixed it or was it a "once done stuffed forever" problem?
Boing is offline
Old October 30th, 2007   #7 (permalink)
Fran's Avatar
Nigel, the light instancing was the suspect in the bloating issue. If the method I described didn't reset your file to the correct size, then it is a different issue entirely and likely has nothing to do with instanced lights.
I will mention that the size of the number in the feedback box - gc() forces Max to do a "garbage collection" - doesn't matter. If you saved the file and it was not restored to the size it is supposed to be, then this is not your issue.
- Fran
Fran is offline
Old October 31st, 2007   #8 (permalink)
Ireland
Have you tried compress on save in File preferences
Worked for me before
Tommy Burns is offline
Old November 1st, 2007   #9 (permalink)
Northern Ireland
I may just end up doing a reinstall and seeing if that cures it, thanks anyway fran.
Tommy, i've never tried that but it surely wouldn't stop whatever is expanding the file it would just compress it to a smaller size?
Boing is offline
Old November 1st, 2007   #10 (permalink)
Ireland
It brought a 20mb file down to 1.2 for me before I'd give it a go, let me know how you get on
Light fixture models with ies files, copyrights pailhead General Discussions 4 September 9th, 2007 06:35 PM
problem loading .max files jeandelessard General Discussions 1 July 4th, 2007 07:38 PM
Question re: Importing CAD into 3ds max 9 and files sizes... VCRUPI 3ds Max 3 February 15th, 2007 06:08 PM
Need help finding autocad files Derek Youssi General Discussions 6 April 13th, 2006 07:38 PM
Cad files into photoshop files Buttman Photoshop 7 September 11th, 2005 01:23 PM
