Autodesk VIZ Autodesk VIZ
Old November 1st, 2007   #1 (permalink)
bully712's Avatar
Exclamation Sunlight Animation
I'm doing a sunlight shadow study for a city block. I got two questions:
1. Can you animate the sunlight system to go from 8am to 8 pm? When I go to the modify panel for the light, I don't see such option.
2. If I cannot animate the light, is there a way to change the time of day without having to create a new light everytime?
Thanks all
I'm using Viz 2008
wireboxdesign.com
rendering the imaginative
bully712 is offline
Old November 1st, 2007   #2 (permalink)
kippu's Avatar
Default Re: Sunlight Animation
did you try out the daylight system?
www.renderviz.com
kippu is offline
Old November 7th, 2007   #3 (permalink)
Ireland
Bully
The answer to both your questions is Yes.
1. to change or animate the settings of the sunlight system you must go to the motion panel. Here you can edit the times, dates etc. of the light. You can set keyframes at 8am, move the timeline on a few frames and set another keyframe for 8pm and the sunlight system will animate the light around your object in a semi accurate way. I say semi accurate because I don't know how accurate Autodesk's system is.
2. Yes, see above.
Hobo Monstrocity is offline
Animation #3 (Apartment in the four-storey house exterior and interiors) PixelRendering Finished Work 7 August 1st, 2007 07:03 AM
vray animation.. shikodesign2000 VRay Render 3 December 15th, 2006 07:12 AM
Animation in VRAY flickering? charadesia VRay Render 2 June 3rd, 2006 02:46 AM
Animation Help steven martin General Discussions 0 July 15th, 2005 01:51 AM
executive wing animation crazy homeless guy Work in Progress (WIP) 30 June 21st, 2004 03:20 PM
