Old November 19th, 2007   #1 (permalink)
Default Render settings as part of Camera
render out put resolution and aspect ratio should be a part of the camera's settings, not controlled discreetly in the render dialogue. this would allow you to send out multiple renders from a single scene without having to constantly change aspect ratios and pixel dimension for each camera, assuming they are different. An override check box could exist in the render dialgue for those that prefer the current method. a output resolution multiplier spinner would also be useful to quickly switch between low, and hi-res output from the render dialogue.
save pointless hassle of constantly toying with apect ratios and resluions of seperate shots. render profiles could also be referenced into the camera controls.
Jefferson Grigsby is offline
Old November 19th, 2007   #2 (permalink)
Chad Warner's Avatar
Default Re: Render settings as part of Camera
this would work especially well if it was able to be animated.
Chad Warner is offline
Old November 19th, 2007   #3 (permalink)
have difficulty understanding the need to animate camera aspect and resolution.
Old November 19th, 2007   #4 (permalink)
Sometimes we'll render images from the same scene that are both portrait and landscape. The way it's set up now, you have to modify the aspect ratio per frame. If it was built into the camera settings and able to be animated, you'd only have to set it once.
Old November 19th, 2007   #5 (permalink)
gotcha, I do the same thing. However, a better solution would be the ability to script renders into Backburner. Create a visual inferface that saves and loads all of your predetermined render, lighting and camera settings, then drag into backburner to run a batch pass.
Sounds too simple, I know. This would save our company hundreds of hours a year. If Autodesk can not pull it off, then maybe we should start hiring programers Lol!!!
Old November 20th, 2007   #6 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
I like this idea - gets my vote
Matt Clementson is offline
Network / Render times / $ ahmon Hardware and Technical Discusions 2 October 20th, 2007 09:09 AM
limited DOF crazy homeless guy General Discussions 6 November 29th, 2006 05:18 PM
dark net render Drunkenbear 3ds Max 9 August 8th, 2006 09:27 AM
Radiosity rant (3D Fluff) Wokka Cinema 4D 12 February 1st, 2005 01:37 AM
