Name: Jefferson Grigsby |
SHORT TITLE FOR SUGGESTION/BUG/ENHANCEMENT REQUEST ---------------------------------------------------------------- better ability to script render passes --------------------------------------------------------------- DETAILED DESCRIPTION OF YOUR REQUEST --------------------------------------------------------------- should be able to take "snap shot" of render settings, independent of render engine, so that various lighting and geometry passes can be recalled when geometry changes or camera changes occur. then a drop down menu willl recall these settings, similar to scene states or saved render settings, but they would be specific to the actual scene. --------------------------------------------------------------- WHY THIS REQUEST IS IMPORTANT TO YOU --------------------------------------------------------------- an example would be creating a script that recalls the specific settings that were used to create an IR pass in Vray, then switch back to another setting that did the final render. too much time is spent switching back and forth when it can easily be scripted. it gets too cumbersome using max's currentl save and load render settings because they are global and not specific to the job. Also, there should be a way to batch process these render "images" directly into Backburner. to save the time of having to asign 20 different passes 1 at a time. Last edited by Jefferson Grigsby; November 19th, 2007 at 03:40 PM. |
| Weird Render Error?? | AFK_Matrix | 3ds Max | 2 | May 9th, 2007 04:34 AM |
| RTT: Render To Texture: workflow needed for assigning maps in matslots | nisus | 3ds Max | 2 | May 22nd, 2006 04:46 AM |
| request to criticise the work | anindia | Work in Progress (WIP) | 4 | April 5th, 2006 02:47 AM |
| Render Elements Crash | lebbeus | 3ds Max | 0 | December 5th, 2004 10:51 AM |
