Old November 19th, 2007   #1 (permalink)
BrianKitts's Avatar
Default Historical Frame buffer memory
The frame buffer should have the ability to flip back through previous renders.
I heard mention that lightwave once had an option that it stored all of your renderings in a working session within it's frame buffer. Then you could step back through your history to compare/reference previous working renderings.
It would be a temporary memory that you could dump to reclaim resources, and of course you would lose it when closing the file, but during an active session your history could be cached.
This could be useful when adjusting lighting and texture for comparing the quality/results. Basically you would have the ability to comparing renders within max instead of having to save out images to be flipped through in an external application.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old November 19th, 2007   #2 (permalink)
Justin Hunt's Avatar
Default Re: Historical Frame buffer memory
I second this one, I have seen it done through the Ram player but havn't been able to work it out. Having used lightwave, its a great way to keep trak of the changes made
JHV
Justin Hunt is offline
Old November 20th, 2007   #3 (permalink)
theqball's Avatar
Correct, RAM Player can do an A/B comparison for two images. Just hit the green teapot for either the A or B channel after you render a test.
Shane Griffith
theqball is offline
Old November 20th, 2007   #4 (permalink)
demo38's Avatar
That is a nice feature in Lightwave. Would be a definite bonus to use this in Max as well. Sometimes A B just isn't enough when you're tweaking multiple objects in a scene.
demo38 is offline
Old November 20th, 2007   #5 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
As an extension of this wish - it would be nice if the VFB had tabs for multiple renders, then the clone button could simply make a new tab rather than an entirely new window.
Matt Clementson is offline
Old November 20th, 2007   #6 (permalink)
How about being able to select two tabs at once to enable a horiz/vert split view mode as in the ram player.
Ray Server is offline
Old November 20th, 2007   #7 (permalink)
Rick Eloy's Avatar
Maybe something as XSI's VFB, where you actually get to drag a line between the new and the old render, so you can compare both quickly.
Rick Eloy
Rick Eloy is offline
Old November 20th, 2007   #8 (permalink)
attached you'll find a screen cap of our "render history"
this saves the last rendered images to a managed local directory using callbacks
it has options for
notes
open in explorer
delete
gamma correction
compare
and open in external programs like photoshop
Thanks.
Mike Gentile
Technical Director
f O C U S 3 6 0 ®
Architectural Communications
www.focus360.com
MikeGentile is offline
Old November 20th, 2007   #9 (permalink)
Rick Eloy's Avatar
Interesting. Is it commercial?
Rick Eloy
Old November 21st, 2007   #10 (permalink)
not commercial at the moment, but we're looking into seeing what tools we may be giving away. this might be one of them
Thanks.
Mike Gentile
Technical Director
f O C U S 3 6 0 ®
www.focus360.com
Duplicate to Max frame buffer Maxer VRay Render 3 July 19th, 2007 11:30 AM
Vray frame buffer vs. MAX frame buffer alvstel VRay Render 1 October 18th, 2006 10:59 AM
render strips using vray frame buffer seamus VRay Render 3 July 24th, 2006 08:29 AM
vray frame buffer at hirez Timothy Saunders VRay Render 7 November 21st, 2005 11:59 AM
about memory, is it really true that...? salf Hardware and Technical Discusions 2 March 30th, 2004 12:59 PM
