Old November 20th, 2007   #1 (permalink)
gfa2's Avatar
Default Render elements and split scan lines with Backburner
Currently (unless I'm missing something) you cannot send a rendering to Backburner that includes split scan lines and Render elements. I'd like to see that corrected.
I'd like to be able to send a high resolution image to Backburner, have an entire renderfarm work on the single image and save out the separate render elements for use in post compositing work. This work-flow is great when using a single machine to produce the rendering, why shouldn't we be able to benefit from this with multiple machines doing the work?
gfa2 is offline
Old November 21st, 2007   #2 (permalink)
Chad Warner's Avatar
Default Re: Render elements and split scan lines with Backburner
This is a good one.
Chad Warner is offline
Old November 22nd, 2007   #3 (permalink)
Yes. I agree. This is a requirement.
Junglejuz is offline
Old February 6th, 2008   #4 (permalink)
Germany
This would be very nice. And I cannot understand why it is not already implemented.
Has anyone found a workaround?
Jan
Amen is offline
Old 1 Week Ago   #5 (permalink)
Germany
Found a solution at least for Alpha channel. Alpha channel assembling worked with TIF until 3dsmax8. PNG is still working in Max2009.
www.einherzfuerpixel.de
classix is online now
1.5 final HAS BEEN RELEASED tdarcy VRay Render 13 August 9th, 2007 10:24 AM
V-Ray Version 1.5 Officially Released! Jeff Mottle CGA News 1 August 9th, 2007 04:48 AM
Render elements with backburner issue brad_ 3ds Max 0 July 26th, 2007 08:21 PM
