Name: Gary Allison |
SHORT TITLE FOR SUGGESTION/BUG/ENHANCEMENT REQUEST ---------------------------------------------------------------- Render elements and split scan lines with Backburner --------------------------------------------------------------- DETAILED DESCRIPTION OF YOUR REQUEST --------------------------------------------------------------- Currently (unless I'm missing something) you cannot send a rendering to Backburner that includes split scan lines and Render elements. I'd like to see that corrected. --------------------------------------------------------------- WHY THIS REQUEST IS IMPORTANT TO YOU --------------------------------------------------------------- I'd like to be able to send a high resolution image to Backburner, have an entire renderfarm work on the single image and save out the separate render elements for use in post compositing work. This work-flow is great when using a single machine to produce the rendering, why shouldn't we be able to benefit from this with multiple machines doing the work? |
Name: Marcus Krott |
Found a solution at least for Alpha channel. Alpha channel assembling worked with TIF until 3dsmax8. PNG is still working in Max2009.
www.einherzfuerpixel.de |
| 1.5 final HAS BEEN RELEASED | tdarcy | VRay Render | 13 | August 9th, 2007 10:24 AM |
| V-Ray Version 1.5 Officially Released! | Jeff Mottle | CGA News | 1 | August 9th, 2007 04:48 AM |
| Render elements with backburner issue | brad_ | 3ds Max | 0 | July 26th, 2007 08:21 PM |
