Old November 22nd, 2007   #1 (permalink)
Justin Hunt's Avatar
Default Revised Revit File Linking
Revit File Linking control
More / better control of how Revit models are File Linked into Max
DETAILED DESCRIPTION
Having the ability to control how Revit models are imported into Max will make handling Revit models more efficient. It is inefficient to have every element of a Revit model as individual elements and as a block in Max. I'd rather have like elements brought in as one object, such as all the glass panes in a curtain wall as one object, the mullions as an other and the frames as an other. If I want to separate then then leave it to me to do it manually.
Max is notoriously bad at handling 10000's of individual objects. Simplifying the object count makes navigation and rendering faster and less prone to crashing.
Justin Hunt is offline
Old December 27th, 2007   #2 (permalink)
Default Re: Revised Revit File Linking
I second you in this request.
I'd like to see this tool in a new release if it's not in 2008 (I'm currently using Max9) with Autocad and Revit.
DapperDanJelly is offline
Need a Revit file! antonio_frias Autodesk Revit 4 April 24th, 2008 03:53 PM
BIM Software ericame General Discussions 16 October 20th, 2007 04:01 PM
Revit / Archicad question jimiperry Autodesk Revit 13 October 19th, 2007 11:50 PM
why use file linking? John Dollus General Discussions 16 June 15th, 2006 06:25 AM
Tips for Installing Autodesk Revit Building 8 using the Web Installer Richard McCarthy Autodesk Revit 2 September 27th, 2005 06:23 AM
