Name: Justin Hunt |
Revit File Linking control ---------------------------------------------------------------- More / better control of how Revit models are File Linked into Max --------------------------------------------------------------- DETAILED DESCRIPTION --------------------------------------------------------------- Having the ability to control how Revit models are imported into Max will make handling Revit models more efficient. It is inefficient to have every element of a Revit model as individual elements and as a block in Max. I'd rather have like elements brought in as one object, such as all the glass panes in a curtain wall as one object, the mullions as an other and the frames as an other. If I want to separate then then leave it to me to do it manually. --------------------------------------------------------------- WHY THIS REQUEST IS IMPORTANT TO YOU --------------------------------------------------------------- Max is notoriously bad at handling 10000's of individual objects. Simplifying the object count makes navigation and rendering faster and less prone to crashing. |
| Need a Revit file! | antonio_frias | Autodesk Revit | 4 | April 24th, 2008 03:53 PM |
| BIM Software | ericame | General Discussions | 16 | October 20th, 2007 04:01 PM |
| Revit / Archicad question | jimiperry | Autodesk Revit | 13 | October 19th, 2007 11:50 PM |
| why use file linking? | John Dollus | General Discussions | 16 | June 15th, 2006 06:25 AM |
| Tips for Installing Autodesk Revit Building 8 using the Web Installer | Richard McCarthy | Autodesk Revit | 2 | September 27th, 2005 06:23 AM |
