Old November 23rd, 2007   #1 (permalink)
Netherlands
Default Instanced Xref scenes
Add the possibility to instance an Xreffed scene. It should be possible to select an xref scene directly in the viewport and instance them. In the Xref scene manager this would be reflected as a treeview. One child is added under the main Xref for every instance.
When filling up an area with the same (detailed) houses it's very handy to use Xref scenes. Any changes to the mother-house are reflected directly in every xref. Now we have to link every house as a single Xref (although it's the same file). Being able to instance an Xref scene in the viewport would speed things up a lot. A second benefit would be that the scene is loaded in memory only once (it's an instance) instead of once for every single xref. The power of Xref scenes would grow inmensely.
klaas nienhuis is offline
Old November 23rd, 2007   #2 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
Default Re: Instanced Xref scenes
I like this idea - gets my vote
Matt Clementson is offline
Old November 23rd, 2007   #3 (permalink)
Chad Warner's Avatar
Definitely like this idea.
Chad Warner is offline
Old November 25th, 2007   #4 (permalink)
England
Yeah, good idea, its like a cross between the functionality of xref objects, but in the scene xref.
I currently do this using object xrefs, but it means you need to attach as many poly objects as possible together in the object to be xreffed to keep it simple.
You can the create slices and the like for sections etc, from the xref objects.
david.jones is offline
Old November 26th, 2007   #5 (permalink)
Netherlands
I've tried to use Xref objects a few times. But when i instanced the xref-objects in the scene and went back and changed stuff in the original xref-file. Those changes only happen in the first instance of the xref in the mother-scene. The other xrefs seem to be unaffected. So keeping it simple seems to be a good in-between solution.
Klaas
Old December 21st, 2007   #6 (permalink)
alias_marks's Avatar
this one gets a vote from me.
www.DownTownMikeBrown.com
alias_marks is offline
xref scene vs xref object akzit 3ds Max 9 1 Week Ago 11:34 AM
Snapping to an Xref Scene JamesTaylor 3ds Max 0 April 19th, 2007 03:10 AM
issue with merge...or XREF salf 3ds Max 4 June 28th, 2005 08:19 AM
Removing missing XREF Objects bwilson 3ds Max 0 November 2nd, 2004 02:25 PM
"Xref object" won't recognize new geometry after I xref object RTurner Autodesk VIZ 0 August 26th, 2004 12:19 PM
