Name: Yudhian Angka |
Hello.
I had a problem made a water material. Does anybody know how to make a good setting for water material in vray? What is fallof used for?? Please help me..thank you |
Name: Jeremiah Spoon |
WWW.Vray-Materials.DE
Falloff is a little tricky to explain. I usually use it in the opacity or reflection map. You can find the description of falloff in the instruction manual. |
Name: fadi freih |
Fall off has to do tith the angle though whitch the camera is viewing the material. if you apply fall of to a table for example, the more you look at the table top horizontally, the more the reflection will be visible. same goes for transparency
Name: Nicholai Kropat |
I generally make my water material almost completely clear (as water usually is) with a small bump map, and a falloff for reflections. I then focus most of my time on making the bottom of the pool, fountain or whatever look very realistic.
-Nick |
| C4D WATER SHADERS | STRAT | Cinema 4D | 28 | October 2nd, 2006 04:42 AM |
| mr problem with glass mr material with dielectric | msamer | 3ds Max | 9 | April 6th, 2006 11:34 AM |
| how to put library material to scene material | oviam | Scripts | 0 | July 8th, 2004 02:10 PM |
