Name: Dean Punchard |
yes, in your materials editor, theres a opacity slot. it uses black and white images (like a bump map). so you need an image of the pattern you want, and adjust it in something like photoshop, so that its a gray scale image. in max, the white part of the opacity material will be totally see through, and the black parts will be solid. any gray between the white and back will be semi transparent, depending on the whiteness of the gray.
you can then map the opacity texture the same way as you would with a diffuse map.
Pikcells Animator, Modelling & Environment Designer |
Name: Yihang Zhang |
that works great with the perforated material.......but how can i get a rusted perforated steel look? i cant seem to use both perforated steel and rusted steel at the same time....
to change the colour of it could be done in photoshop, just change the colour of the bitmap??? What render engine are you using??? I use mental ray and i'm just rendering a quick material using the perforated metal bitmaps that ship with max, will post it when its done, then i will try and add some rust. the arch and design materials in mental ray are a great place to start
also to add the rust try using a 'mix map' in the diffuse slot, then you could try adding the metal material in the colour 1 swatch of the mix map, and the rust bitmap in the colour 2 swatch, let me know how it goes, post some renders of your material so far, it makes it easier to advise and also to see what you are trying to do
| How To Make a Hull with Line Spline | SandmanNinja | 3ds Max | 3 | May 27th, 2007 12:41 AM |
| make preview problems in 3dmax7 | maxkid | 3ds Max | 1 | August 22nd, 2006 05:01 AM |
| gradient perforated metal | awdb0404 | 3ds Max | 5 | July 21st, 2005 07:27 AM |
| Cloth to make a nice bed-spread | Rick Eloy | 3ds Max | 6 | July 9th, 2005 11:06 AM |
| Rendering Stainless Steel | mesht | General Discussions | 3 | April 7th, 2005 10:27 AM |
