| Finished Work Post your final 3D Art works here to be critiqued by other board members. |
Hi all, I'm back again with new project.
I have provided some interior and exterior views, And it's nice to know your Ideas. Software : Max 9.0 and vray & photoshop, C&C are welcome. I have faced some bad memory problems with win xp 32bit and I wanna switch to 64bit. I have an error like this: "Bitmap paging file error because of low memory.. the bitmap may render incorrect" and something like this.. I have 3GB of DDR2 Ram, But when I recieve this error its used arround 1.3GB. In the other hand when I use Max environment in dirrect3D mode, I offen get critical errors causes terminate the application!! Thanks. |
Name: Phillip Grimshaw |
Hi, nice renders, i like them. Reflections on the windows of the exteriors are a bit overpowering and it would be nice to see some depth in there. But i know there isnt always time!
Well done. |
Name: Brian Kitts |
Great images there really isn't too much to comment on.
My biggest suggestion would be to drop in some background enterouge between your scene and the the sky. The exteriors are are superb, but there is nothing grounding them to the rest of the world... you have the focal house, the surrounding enterouge then it breaks and goes straight to the sky. Almost as if your scene is composed in an empty world. A distant skyline or treeline would be the last missing piece to a great image. On the last two exteriors: I would turn down the displacement distance on the grass. It's turned up so high that it looks unrealistic.... I would suggest trimming it up, someone falls in that yard they might impale themselves The only other comment would be to lose the frame stamp. Personally I'm not interested in what rendering engine you use, or how long your rendering took. I feel that a good illustrator can work his/her magic regardless of what software they use... and a good image isn't about how you did it, its about the end product. If you are going to take the time to watermark the image with your company logo and call it a final, then take the time to turn off or crop out the vray frame stamp. all the same it's a pleasure to see quality work. -bk Last edited by BrianKitts; December 24th, 2007 at 04:47 PM. |
Dear Brian, Thank you very much for your exact and nice Ideas.
About the stamp really you'r right and it was a pro point I have used 3dmodels (Proxy) as plants, in middle of image or on background. So there was not a soft or ample treeline. I have bought a totaltextures of plants (trees) I hope they help. I will test it and put my result images as soon as possible. Thanks. |
| Stainless steel for box | nilariver@gmail.com | General Discussions | 1 | April 29th, 2007 10:26 AM |
| 300 homes + school + green areas project | -wolts- | Finished Work | 16 | December 23rd, 2006 04:49 AM |
| stainless steel effect | ksampath | 3ds Max | 2 | July 24th, 2005 01:05 AM |
| Rendering Stainless Steel | mesht | General Discussions | 3 | April 7th, 2005 10:27 AM |
