Go Back   CGarchitect.com > 3D SOFTWARE > SketchUp
SketchUp @ Last Software SketchUp
Old December 20th, 2007   #1 (permalink)
Default Mapping an image onto a terrain
I have followed the process of mapping an image onto a terrain step by step, and still the image appears to be fragmented. I've gotten this to work before, and for whatever reason I can't get it this time. Does anyone know of anything that I could be doing wrong... here is a screenshot.
In this image you can see I have a plane setup to the right size, above my terrain, and the terrain below still has a fragmented image.
Any help would be appreciated!
cferman is offline
Old December 26th, 2007   #2 (permalink)
xpumasx's Avatar
Default Re: Mapping an image onto a terrain
Make sure both images are in the same group and then right click the texure, go to the Texture menu and make sure PROJECTED is checked.
- V a l e r o S t u d i o -
www.valerostudio.com
matt@valerostudio.com
xpumasx is offline
Old January 8th, 2008   #3 (permalink)
I finally figured this out - somehow or another I had a different image mapped to the bottom side of the top plane that was interferring with projecting it onto the terrain. Thanks for the help!
cferman is offline
Help! Large image comes out really bright! 3dpatient2 VRay Render 21 February 5th, 2007 02:42 PM
Viewport Image Problems MesaPrs Autodesk VIZ 3 November 21st, 2006 08:21 PM
Terrain modelling nightmare Jeff Mottle 3ds Max 14 December 4th, 2004 04:33 PM
bitmap image quality in Max viewports Brett 3ds Max 1 July 22nd, 2004 08:19 AM
Terrain Problem with Sketchup, how do you stop triangulation when importing? Richard McCarthy SketchUp 1 May 10th, 2004 10:46 AM
