Autodesk VIZ Autodesk VIZ
Old December 25th, 2007   #1 (permalink)
piotrgreg's Avatar
Name: Piotr Grzegorczyk
Poland  Send a message via Skype™ to piotrgreg
Default trouble with file linking *dwg file in viz
Hi everybody
the problem is:
I have recently upgraded my Viz to 2008 version as well as recent Vray
I have a big problem with linking *dwg files from Acad - I can't reload my file without missing my materials definitions on reload - I have already studied viz help file ab reloading quite long , but it seems to me there's some other problem involved. Do anyone of You have faced same problem? Is ther any solution?
I ll appreciate quick response
Piotr
piotrgreg is offline
Old December 25th, 2007   #2 (permalink)
Default Re: trouble with file linking *dwg file in viz
hi,
u have to make a new preset that will have both "use scene material difintion " and " use material assignment on reload" turned on, then use that preset at the begining when u link your autocad file.
without using that preset at the begining you cant keep the link in the right way.
colorID is offline
Old December 26th, 2007   #3 (permalink)
piotrgreg's Avatar
Mohammed,
as I've mentioned, I have studied help file and, of course "Use Scene Material Definitions" and "Use Scene Material Assignments on Reload" functions are ON with the very first linking.... and there's still a problem
any other idea?
Piotr
Old December 26th, 2007   #4 (permalink)
Ray
Ray's Avatar
http://usa.autodesk.com/adsk/servlet...linkID=9242899
Ray is offline
File Linking from CAD asarria 3ds Max Wish List 2 February 7th, 2008 05:58 AM
Revised Revit File Linking Justin Hunt 3ds Max Wish List 1 December 27th, 2007 12:36 PM
Vray Proxy with AutoCAD file linking alfienoakes VRay Render 4 November 26th, 2007 03:26 AM
FileLink in Max 9 crazy homeless guy 3ds Max 12 April 1st, 2007 07:24 PM
why use file linking? John Dollus General Discussions 16 June 15th, 2006 06:25 AM
