3ds Max Autodesk 3ds Max
Old December 27th, 2007   #1 (permalink)
Default 3ds Max 9 - File Corruption
My office is currently running Max 9 on both 32 and 64 bit stations. Since our move to Max 9, a lot of our files are being corrupted. The majority of the corrupted files are being worked on and saved from one particular workstation running Max 9 x64. There are 3 other machines in our office that are identical to this workstation. The only difference that I can ascertain, the person at this workstation likes to have multiple max sessions open (sometimes 4 scenes). My thoughts are that this has something to do with the corrupted files.
I just wanted to get people’s thoughts of having multiple instances of Max running. My personal max practice is to only have one instance running, and if for some reason I need to jump in another model I will save and close that session, then open the other file.
We are still trying to narrow it down, any thoughts would be appreciated.
mrucereto is offline
Old December 27th, 2007   #2 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Re: 3ds Max 9 - File Corruption
interesting. i am on a 64 bit machine, and often run 2 or 3 instances of max at any given time. i do experience corruption quite frequently, but i never thought it to be from that...
i like to work with xref'd scenes. typically around 4 or 5 xref'd scenes to a project. my corruption problem typically happen in the master file where the other scenes are xref'd to. the file will start crashing while trying to load the xref'd scenes on opening. i have a work around, so it is more of a neusance than anything.
i never considered the fact that i was running multiple instances to be causing the corruption though.
___
edit: i am on a 64 machine, but running max 32.
travis schmiesing
crazy homeless guy is offline
Old December 27th, 2007   #3 (permalink)
I haven't made the move to 64-bit yet, but I typically have 2 or 3 Max sessions open -1 doing render tests, one modeling, and maybe one rework, etc, and I almost never have an issue, and I've worked this way since Max2. I get corruption maybe 3 times a year -usually due to a crash- but I always use iterative save, and I always keep the last 2 iterations because we all know how flaky Max is.
DavidR is offline
accuracy of 3ds max modeling xueming 3ds Max 2 December 11th, 2007 04:00 PM
Difference between Max and Maya whale General Discussions 16 July 20th, 2007 02:08 PM
3DS max 3ds max, it's all i hear about!!!!!! chalk General Discussions 31 May 30th, 2007 05:23 AM
Sketch-up to 3ds Max Problems choppir 3ds Max 5 July 6th, 2006 08:23 AM
3d to 2d using 3ds max and autocad Pete 3ds Max 2 September 22nd, 2005 03:18 AM
