Old January 2nd, 2008   #1 (permalink)
Default model export to previous Max versions
Allow export of base model from Max to earlier version of Max. I don't understand why I can't export a collapsed poly object from Max9 to Max7, then reapply Meshsmooth , UVW, etc. This could even be a utility, like stl check, that verifies if your model is exportable to a previous version.
Why this is important to me
Many things are OK exported as .3ds or .obj, but some require extensive cleanup after import, so retension of .max for some models is very important.
DavidR is offline
Old January 2nd, 2008   #2 (permalink)
DennisHolland's Avatar
Name: Dennis de Priester
Netherlands  Send a message via Skype™ to DennisHolland
Default Re: model export to previous Max versions
There are a few 'back from' tools in the field. Don't know where to get 'm but they're there. Maybe scriptspot.com?
Dennis
__________________________________________
PRIESTERMEDIA
3D Visualisaties & Presentaties
Rotterdam, the Netherlands
DennisHolland is offline
Old January 3rd, 2008   #3 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
It's a good wish but I'm not sure if it's even technically possible because of the way the .max format works. Unlike .3ds for example the .max file is not a series of vertex/face arrays but a snapshot of the current state of all the plugins used in the scene. Plugin recompiles are designed to read older data but obviously there's no way you can programme an earlier version to read future data unless you happen to know what that future plugin is going to be like (in which case - go play the lottery!).
Matt Clementson is offline
Old January 3rd, 2008   #4 (permalink)
MS Word, Exel, etc, can do it, and I'm only asking to save an editable poly/mesh without modifiers going backward, not fwd.
DavidR is offline
Revit Max, and Autodesk Jefferson Grigsby General Discussions 3 March 13th, 2008 09:15 AM
Import a .C4D file into MAX (using whichever export format) Logitek 3ds Max 0 April 5th, 2007 02:56 PM
Revit To Max, Why Such A Nightmare?? Jefferson Grigsby AutoCAD/AutoCAD Architecture 2 August 5th, 2006 12:28 PM
3ds max 8 won't launch on Opteron/WinXP64 render nodes ShaunDon Hardware and Technical Discusions 8 July 8th, 2006 09:16 PM
max backpack model Travis_kinney General Discussions 0 December 9th, 2003 01:22 AM
