Autodesk VIZ Autodesk VIZ
Old January 7th, 2008   #1 (permalink)
Singapore
Default water in autodesk viz material editor
i have problem creating water in the material editor of viz 3d? is there an tutorial?
canneth1112 is offline
Old January 8th, 2008   #2 (permalink)
Default Re: water in autodesk viz material editor
Do you need static water or is it for an animation? Certain water effects can be done but some need the particles available in Max.
Surface Water Tutorial:
http://www.3dcadmax.com/MaxWaterTutorials.htm
Hugh_Compton is offline
Node Based Material Editor / Hypershade hansn 3ds Max Wish List 4 March 17th, 2008 03:52 AM
Water Material. yudk VRay Render 4 December 17th, 2007 08:19 AM
Using merged model's Vray materials in your current Material Editor estyl VRay Render 2 January 16th, 2007 08:04 PM
need help with my material editor dnagi 3ds Max 4 April 21st, 2006 07:59 AM
Material Editor issue raterry 3ds Max 2 September 28th, 2005 04:12 PM
