Name: Taka Shimeki |
modo can import dxf files. But,
Probably better to convert dxf into lwo file first, then import it into modo. check http://www.micromouse.ca/ |
#3 (permalink) | |
Name: ben felder |
Name: Neil Hayes |
I use dxf -> accutrans -> modo, although modo has DXF import I prefer to use accutrans as it has more options.
For those that don't have AutoCAD for DWG to DXF one can use use software such as the A9 convertor: http://www.a9tech.com/products/a9converter/ Also, DWG TrueView (free from AutoDesk) is useful for converting DWG from the latest versions of AutoCAD to earlier incarnations. This can help if you're having compatibility issues when using DWG to DXF convertors.
Don't resist. Try flowing. |
| Linking dwg files to Maya | pixel8 | Maya | 2 | June 18th, 2008 01:04 PM |
| Importing DWG files, | Rendermedia | General Discussions | 2 | November 29th, 2007 08:10 PM |
| from dwg files to model -best practice? | eoghan | Cinema 4D | 3 | February 9th, 2006 06:53 AM |
| Diffuse maps on imported DWG files. | Cirrus | 3ds Max | 2 | December 18th, 2005 10:09 AM |
