Go Back   CGarchitect.com > 3D SOFTWARE > Modo
Modo Luxology Modo
Old January 8th, 2008   #1 (permalink)
Default Utilizing DWG files
What is the work flow for using AutoCAD DWG files with Modo?
stezza is offline
Old January 10th, 2008   #2 (permalink)
4d-infinite's Avatar
Default Re: Utilizing DWG files
modo can import dxf files. But,
Probably better to convert dxf into lwo file first, then import it into modo.
check http://www.micromouse.ca/
4d-infinite is offline
Old January 14th, 2008   #3 (permalink)
bentegviz's Avatar
that's pretty much what we have to do as well. using deep exploration or accutrans. lwo gives you the least hassles in the import.
bentegviz is offline
Old January 20th, 2008   #4 (permalink)
I use dxf -> accutrans -> modo, although modo has DXF import I prefer to use accutrans as it has more options.
For those that don't have AutoCAD for DWG to DXF one can use use software such as the A9 convertor:
http://www.a9tech.com/products/a9converter/
Also, DWG TrueView (free from AutoDesk) is useful for converting DWG from the latest versions of AutoCAD to earlier incarnations. This can help if you're having compatibility issues when using DWG to DXF convertors.
Don't resist. Try flowing.
nhayes is offline
Linking dwg files to Maya pixel8 Maya 2 2 Weeks Ago 01:04 PM
Importing DWG files, Rendermedia General Discussions 2 November 29th, 2007 08:10 PM
from dwg files to model -best practice? eoghan Cinema 4D 3 February 9th, 2006 06:53 AM
Diffuse maps on imported DWG files. Cirrus 3ds Max 2 December 18th, 2005 10:09 AM
SEO by vBSEO 3.1.0
