Old January 15th, 2008   #1 (permalink)
Timothy Saunders's Avatar
Default Save Back Option
Option to save back to older version.
When saving or exporting a file, it would REALLY be helpful to be able to save the file for older versions of max.
I understand there are some plugins, or geometry types that aren't usable in older formats, but in the save or export process, maybe you would just get a warning that the objects in the scene that use those new features could not be saved in the scene.
I have projects all the time when consultants or partners on the project don't have the same version of max.
Timothy Saunders is offline
Old January 15th, 2008   #2 (permalink)
Rick Eloy's Avatar
Default Re: Save Back Option
'Nuff said. Yes from me!
Rick Eloy
Rick Eloy is offline
Old January 15th, 2008   #3 (permalink)
Chad Warner's Avatar
This should have been the first wish!
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old January 15th, 2008   #4 (permalink)
kippu's Avatar
oh yes .... seconded or thirded.....
www.renderviz.com
kippu is offline
Old January 15th, 2008   #5 (permalink)
I had a similar wish in the Wish List -maybe they should be consolidated?
DavidR is offline
Old January 15th, 2008   #6 (permalink)
TheAllusionist's Avatar
Yes, this would probably be a lot of peoples #1 wish, but does anyone really think the lack of this feature is an oversight on Autodesk's part?
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind.
3DAllusions | 3DAllusions Studio | MrMaterials
TheAllusionist is offline
Old January 16th, 2008   #7 (permalink)
Rick Eloy's Avatar
Not really. I assume it's probably due to 3 reasons:
1) New compilers come out, and Max uses those. When you change the compiler, everything changes, including plugins. So, I think it must be a real pain to create something readable by a previous version (again, not an expert on this so I might be wrong)
2) Since Max works with plugins, somethings simply do not exist in older versions, so it probably wouldn't read the files right.
3) They now lauch a new release every year, and this makes people buy it (this one everyone knows, already).
Rick Eloy
Old January 16th, 2008   #8 (permalink)
All very good points. The third one is the only one I would have thought was an obstacle, a majority of the programs out there save out to older versions. As for plugins, if the feature wasn't available for the version you saved the file out as, then I assume when you are using the older version of Max you wouldn't have the non-existant plugin installed. Compilers, I would have thought with as old and ancient max's code is that there would be no surprises there.
But the fact probably is that something on your list or another reason is in affect here, otherwise I would think someone would have written a plugin to do this So as jaded as my opinion on it is, there are probably some legitimate reasons for it. But I imagine the #1 reason is the 'Board of Investors'! LOL
Great Wish Item!
Old January 16th, 2008   #9 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
For completeness' sake, It should be noted that you can get very good backward compatibility by using the newest versions of the FBX file format. (From the adesk FBX website, not the one that comes with max)
It may not be perfect, but its worked great for me in 4 of 5 cases here.
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Old January 17th, 2008   #10 (permalink)
How well are the geometry "types" preserved? Meaning; I can get great looking 3ds exports, but what I want is to have access to modifiers, and things like changing the shape or path of a loft. With a 3ds export, it is all converted to an editable mesh. Is that the same with FXB? Never tried it.
IES lights losing information after Save in 3d max geardaddy1 3ds Max 0 September 26th, 2007 03:03 PM
1.5 final HAS BEEN RELEASED tdarcy VRay Render 13 August 9th, 2007 11:24 AM
V-Ray Version 1.5 Officially Released! Jeff Mottle CGA News 1 August 9th, 2007 05:48 AM
Which is the better option? 3DImageWorks Hardware and Technical Discusions 9 January 24th, 2007 12:52 PM
