Autodesk VIZ Autodesk VIZ
Old January 16th, 2008   #1 (permalink)
Aaron2004's Avatar
Name: Aaron Nordstrom
Default Linking a doorknob to a door
Hello,
I am using a door primitive and want to add a doorknob to it that moves with the door's swing. I can link the door knob to the door object itself, but not to the the particular element that I want. Is this possible?
Also, I've searched around to no avail. Are there custom add-ons/scripts for these door primitives? They seem pretty stripped down and could use a good revamping.
Thanks,
Aaron
Aaron2004 is offline
Old January 16th, 2008   #2 (permalink)
Default Re: Linking a doorknob to a door
You could collapse it with the door, keeping material ID's.
ipxstudios is offline
Old January 16th, 2008   #3 (permalink)
If you are using Max doors then you may have an issue with linking the door hardware. I haven't had any luck either with those.
Old January 17th, 2008   #4 (permalink)
Aaron2004's Avatar
Thank you, Julian. I am just going to detach the element that I want...it seems like I can't link the door knob to it in the state it's in right now.
Door/ Window Assembly Clean-Up JMBknvc AutoCAD/AutoCAD Architecture 0 August 10th, 2006 04:59 PM
why use file linking? John Dollus General Discussions 16 June 15th, 2006 06:25 AM
creating an arched door for an assembly RAYMOND AutoCAD/AutoCAD Architecture 0 December 15th, 2005 12:34 PM
ADT Door material m_cubed Autodesk VIZ 2 August 9th, 2004 04:20 PM
VW -> C4D Door symbol problems Chris H Cinema 4D 0 May 30th, 2003 04:29 AM
