Old January 18th, 2008   #1 (permalink)
Default environment
Hello
I´m new to Mental Ray after having much experience with VRAY (at the new job no one wants to learn vray). I want to put a jpeg or hdri as an environment map so that clouds, etc are reflected in the windows, metal, etc. In VRAY I could put the map in the environment slot in the environment tab and achieve the desired effect. However, I´m quite lost in Mental Ray. I´ve tried doing several tests and looking for documentation online, but haven´t had much success. I saw a post by Jeff Patton on using a skydome, which did work. However, say I were to use a MR Physical Sky and I wanted to use an environment map with clouds? I tired putting a map in the glass material in the environment slot, but didn´t have much luck. I tried bumping up the output amount and that didnt help much. Any ideas? Thanks.
b2dr is offline
Old January 18th, 2008   #2 (permalink)
Ireland
Default Re: environment
All you have to do is change your physical units to about 90,000 instead of exterior daylight
Let me know if it works for you
Tommy Burns is offline
Old January 18th, 2008   #3 (permalink)
Brian Bradley's Avatar
Hi Brendan,
So long as you are using the 'Max' environment slot (8)
and not the Vray specific one, the process for putting
an image as your Environment is exactly the same as
VRay. In fact the steps you have described should
work! Can you post up an image of what you are getting/
Regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old January 23rd, 2008   #4 (permalink)
Hello
I did some tests. I was trying to find something similar to the VRAY environment for Mental Ray. Maybe this will be helpful for someone. In the end I used a rayswitch inthe environment slot (8) in which the eye rays are the physical sky and the refracted, reflected and environment rays are the hdri. The image needs some work, but it was kinda the idea of obtaining a global environment override that I was looking for.
I tried putting the HDRI as a map in haze. It gave a strange effect.
In another test I put the HDRI directly in the environment (it didnt work before because I had strange photographic settings). When I did this, the HDRI appeared in the environment and in the background, as it should. But if this is the case, what is the point of making one of these "skydomes" that people refer to from time to time?
The only glitch is that there is a blue blob in the image from the HDRI. If I rotate it, it disappears. But if I do multiple views from different angles, I assume that I would have to rotate it again. Anyone know how I can get rid of the "blob"? or minimize it? perhaps by using the U or V offset or tiling?
I like the MR physical sky though. any one have any ideas on had one could add some clouds to it?
b2dr is offline
Old January 23rd, 2008   #5 (permalink)
MasterZap's Avatar
Name: Håkan Andersson
Sweden
Originally Posted by b2dr View Post
Hello
What's this blue blob from? Is it actually in the HDRI image, or what?
/Z
MasterZap is offline
Old January 23rd, 2008   #6 (permalink)
its supposed to be an HDRI. here´s a screenshot of the material. I rotated it so you can see the blue. If you know what Im doing wrong, please let me know. thanks
b2dr is offline
Old January 23rd, 2008   #7 (permalink)
Ireland
Hi I get this all the time it is like the both edges of the map meeting
what i do to get rid of this is animate the map by using offset U in each frame
Hope this makes sense
Old January 23rd, 2008   #8 (permalink)
yeah, it makes sense, that´s what i did. but in any case, it would be nice to find a way to avoid doing that if possible. So if anyone knows, please share.
thanks
b2dr is offline
Old February 5th, 2008   #9 (permalink)
shaneis's Avatar
Set the HDRI mapping from "Spherical" to "Angular".
NB: These are Maya settings, I'm assuming it is the same in Max
shaneis is offline
Old February 5th, 2008   #10 (permalink)
shaneis's Avatar
Found it!
shaneis is offline
Environment Dialogue box gone AWOL jimbobjones General Discussions 2 January 18th, 2008 07:16 AM
Reflective Slot / Environment Andrew1 VRay Render 3 December 12th, 2006 11:22 AM
environment background problem please help neldy18 VRay Render 6 August 22nd, 2006 08:09 AM
Environment maps aflack 3ds Max 7 June 2nd, 2004 11:26 AM
Environment reflections? Brian Cassil 3ds Max 1 July 3rd, 2003 07:20 AM
