Old January 18th, 2008   #1 (permalink)
Default Glass reflection on double glazed windows
hello all,
does anyone bother modelling double glazed windows? if so, do you use two planes or two boxes, or some other method?
whilst real glass in windows usually show slightly offset double reflection, most of the cg renders have pretty perfect reflections on glass and i don't think this is very accurate.
the only problem with modelling double glazing is that it makes the 'dark objects through glass' issue even worse.
thoughts?
derek forreal is offline
Old January 23rd, 2008   #2 (permalink)
Default Re: Glass reflection on double glazed windows
have i asked a really silly question?
Old January 23rd, 2008   #3 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
Depends on the requirements of the model I'm building but I have modelled them properly in the past. Usually if they're seen at a distance then I don't bother as you can usually do it easier in post.
Matt Clementson is offline
Weird Glass Reflection jophus14 VRay Render 3 September 13th, 2007 08:58 AM
vray light seen in the glass reflection Koper VRay Render 3 January 18th, 2007 05:58 AM
Reflected glass windows.. shikodesign2000 VRay Render 4 January 4th, 2007 05:57 AM
VRay Kitchen : Glass reflection problem? purnomo_adi Work in Progress (WIP) 5 May 26th, 2006 12:42 PM
BUG fix for SP4 released mauarduz General Discussions 0 August 5th, 2003 12:57 PM
