Old January 18th, 2008   #1 (permalink)
Default 'Cut' uses angle snap / axis constraints
'Cut' uses angle snap (or axis constraints at the very least)
the 'cut' command uses the angle snap that i have set. i.e. click once to place cut start point, cut guide line then snaps to angles specified in the angle snap rollout so i can make an accurate cut at any angle
i could use the 'slice' tools but it's a lot slower as you have to first rotate and manouvre into position. the cut tool is great but difficult to cut along the desired line if you are slicing through edges or polys
derek forreal is offline
Angle Snap Settings Problem thickly AutoCAD/AutoCAD Architecture 3 June 1st, 2007 10:35 AM
M7: axis constraints / align tool nisus 3ds Max 4 February 2nd, 2005 02:43 PM
