Old January 31st, 2008   #1 (permalink)
Default Mental Ray Problem
I'm making neon lights for a city. I press F9 and I get this message saying:
PHEN 0.3 error 051011: shader "max_is_material_editor" not found
PHEN 0.3 error 051011: shader "max_DefaultMaterial" not found
PHEN 0.3 error 051011: shader "max_SpotLight" not found
PHEN 0.3 error 051011: shader "max_OmniLight" not found
PHEN 0.3 error 051011: shader "max_base_Curve" not found
PHEN 0.3 error 051011: shader "max_base_CurveControl" not found
PHEN 0.3 error 051011: shader "max_base_Output" not found
PHEN 0.3 error 051011: shader "max_Falloff2" not found
PHEN 0.3 error 051011: shader "max_base_BlinnIllumination" not found
PHEN 0.3 error 051011: shader "max_StandardMaterial" not found
PHEN 0.3 error 051011: shader "max_base_UVGenerator" not found
PHEN 0.3 error 051011: shader "max_Bitmap" not found
PHEN 0.3 error 051011: shader "max_Environment" not found
PHEN 0.3 error 051011: shader "max_base_GBuffer_lens" not found
PHEN 0.3 error 051011: shader "max_base_VideoColorCorrect" not found
PHEN 0.3 error 051011: shader "max_base_ImageCollector" not found
PHEN 0.3 error 051011: shader "max_base_VideoSuperBlack" not found
PHEN 0.3 error 051011: shader "max_DefaultLight" not found
Is There anyway that I can fix that?
maxiedaman is offline
Old January 31st, 2008   #2 (permalink)
Default Re: Mental Ray Problem
Also, those spheres in the material wont show, and it's pure black.
Old January 31st, 2008   #3 (permalink)
Ireland
Looks like you need a re-install of max cos you have lost a lot of links there
unless someone knows where to find them again?
Tommy Burns is offline
Old January 31st, 2008   #4 (permalink)
Everything's there. It's mental ray that I'm having problems with, cause I just used it an hour ago, I didn't delete anyhing, and the message pops up on my screen.
Old January 31st, 2008   #5 (permalink)
Ireland
Maybe a restart might do it or else create a new scene and merge?
Old January 31st, 2008   #6 (permalink)
Didn't work.
Old January 31st, 2008   #7 (permalink)
Brian Bradley's Avatar
Hi Micheal,
Any chance you can post your scene? If we can
use it OK then it is going to be a local problem!
If not then something in the scene is not playing
nice.
Regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old January 31st, 2008   #8 (permalink)
Originally Posted by Brian Bradley View Post
Hi Micheal,
nice.
Regards
Bri
How do u do that. Sry. I'm new here.
Old January 31st, 2008   #9 (permalink)
Hi Micheal,
As you make your reply to a post, if you scroll
down the page a little you will see a button
named 'manage attachments'. Clicking on this
allows you to upload images and small (best Zipped)
files to the forum.
Regards
Bri
The MBM Blog
www.vrayelite.com
Old January 31st, 2008   #10 (permalink)
It's working now. The stupid program was playing mindgames with me.
Problem Whit Mental Ray brigante Mental Ray 10 December 20th, 2007 02:06 AM
Mental Ray render problem winterlight 3ds Max 7 August 22nd, 2006 09:57 AM
Mental Ray bucket problem arkitekten 3ds Max 3 October 26th, 2004 08:40 AM
Huge Mental Ray Problem akropol2000 3ds Max 3 July 20th, 2004 12:02 AM
