3ds Max Autodesk 3ds Max
Old January 31st, 2008   #1 (permalink)
Name: Mark Frankmann
Default Odd spinner behaviour
Suddenly my Max 2008 seems to have strange spinner behaviour.
In the preferences settings spinners section I have snap = 1 and Use Snap checked. I have precision set to 2 decimals.
I can drag the spinners to change the values. When I toggle the spinner snap button to on it has no effect I have to click the spinner buttons multiple times to get a whole number increase. When I type in a value and enter it uses the next lower number. I type in 3 and hit enter, the value is set at 2.
I think I inadvertently caused some setting change but I can't figure out how to fix this.
Can anyone help me with this?
Thanks.
Mark Frankmann
Open Range Imaging
www.openrangeimaging.com
markf is offline
Old January 31st, 2008   #2 (permalink)
Default Re: Odd spinner behaviour
OMG, just read in another thread to check world units. I had imported some base drawings that were in meters. This seems to be the root problem. Thanks CG Architect forum!
Now need to try and fix (re-scale) what I've dome so far.
Mark Frankmann
Open Range Imaging
markf is offline
Old January 31st, 2008   #3 (permalink)
AJLynn's Avatar
That's the problem - you should be using Imperial units!
AJLynn is offline
Odd reflections tbny 3ds Max 1 April 11th, 2007 11:14 AM
Odd Speckling. Help? TheGrandmaster1 VRay Render 7 November 14th, 2006 10:43 AM
Odd glow... Ky Lane VRay Render 4 August 29th, 2006 08:30 AM
Odd render problems leed Cinema 4D 11 November 6th, 2005 05:13 AM
