3ds Max Autodesk 3ds Max
Old February 1st, 2008   #1 (permalink)
Brian Cassil's Avatar
Default objects don't display in max 2008?
Has anyone else here had issue with objects not displaying in shaded viewports? I'm starting on a scene and there are less the 5K polys now and I have some objects that only display in wireframe or when I select them in a shaded view. Another 3D guy that works with me has had the exact same problem several times as well. Any thoughts/fixes?
"writing notes is quieter."
Brian Cassil is offline
Old February 1st, 2008   #2 (permalink)
Default Re: objects don't display in max 2008?
A couple more clues: It seems to be limited to objects I have instanced and when I turn on "edge faces" everything appears normally.
edit: scratch the instanced object thing. It is limited to objects that have materials assigned to them. Anything with a material assigned doesn't appear in a shaded view with edge view turned off. Anything that doesn't have a material assigned appears normally.
Old February 1st, 2008   #3 (permalink)
Chad Warner's Avatar
Sounds like a graphics card problem, though I wouldn't know the solution.
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old February 2nd, 2008   #4 (permalink)
Same too.
No solution yet.
okmijun is offline
Old February 4th, 2008   #5 (permalink)
I'll check the max forums and see what I find.
Old February 4th, 2008   #6 (permalink)
IceAged's Avatar
United Kingdom  Send a message via MSN to IceAged
In Max 2008, you say? Yes I have had very similar problems, even when viewing just a handful of objects in isolation mode. It's specific only to the computer I am working on, and it only seems to affect one specific file.
I'm going to try merging the contents and materials into a new file, just that I haven’t done much with that project lately so it's not been a priority. I'll let you know if it works.
Here's the post I started a while back, if it's of any help...
http://www.cgarchitect.com/vb/27532-...-disaster.html
IceAged is offline
Old February 4th, 2008   #7 (permalink)
Tommy L's Avatar
I have the same problem. Ill be watching this thread.
Oh, I have Max 2008 running on XP64 and an Nvidia 7600GT with the latest drivers. Max is using DirectX9.
Im also still having menu display problems. Also, floating menu problems. None of these things are critical, can still work, but when you pay $4k for software, you want it to work properly...
Tommy L is offline
3ds Max 2008 Architectural Visualization - Beginner to Intermediate Jeff Mottle CGA News 7 January 19th, 2008 03:26 PM
Autodesk 3ds Max 2008 Now Shipping Jeff Mottle CGA News 0 December 5th, 2007 12:01 AM
RPC Objects from previous Max versions fts 3ds Max 6 December 2nd, 2007 12:28 PM
DirectX 10 "grayed out" as Direct3D driver in 3ds max 2008? robkar97 3ds Max 2 November 21st, 2007 03:09 PM
Lost Max display frank1331 Hardware and Technical Discusions 3 August 18th, 2006 06:41 PM
