Name: Robert Karlsson |
I find that textures, especially lighter ones, gets washed out and milky with the default settings for mr photographic exposure control. Pure colors, like r=1.0, g=0.0, b=0.0 looks ok, but r=1.0 g=0.5 b=0.5 looks very different in the material editor and the renderings...
![]() If I pull the "midtones" down all the way to 0.5 (from 1.0) I get better results, but this seems very drastic (?). Then the darker details tend to get too dark :-) ![]() The manual says that no gamma correction should be needed if using mr photographic exposure control. Tweaking every single map using the output options also doesn't seem like a good approach. Anyone sharing this experience? All the best Robert |
#2 (permalink) | |
Name: Håkan Andersson |
This is a gamma issue; you need to de-gamma your textures using the input gamma in the file dialogs.
Gamma + the logarithmic control is asking for trouble, though. /Z
mentalraytips.blogspot.com - mr Zap Andersson - a completely mental shader guy |
Thanks for the input Z.
This is a quote from the 3ds max 2008 help (Arch + design material): "Note: When using the mr Photographic Exposure Control, the need for gamma correction is largely replaced. Use either gamma correction or the mr Photographic Exposure Control, but not both." What kind of gamma setup do you recommend? Using LUT or simply a float value? Robert |
| Vray and exposure control preview | frank1331 | VRay Render | 6 | October 29th, 2007 03:31 AM |
| Augmented Reality: Looking through the window / Exposure Control | nisus | 3ds Max | 9 | November 7th, 2005 02:57 AM |
| Artlantis R and Exposure Control | AJLynn | Other 3rd Party Renderers | 2 | July 28th, 2005 10:12 AM |
| Skydomes v's exposure control | Jim Mann | 3ds Max | 2 | May 20th, 2003 03:29 AM |
| Radiosity, Logarithmic Exposure Control, and Bitmaps | Matthew Boorstin | Autodesk VIZ | 6 | July 1st, 2002 01:31 AM |
