Go Back   CGarchitect.com > ARCHITECTURAL VISUALIZATION COMPETITION > AVC Competition Archives > 2007 Architectural Visualization Competition
Old February 5th, 2008   #1 (permalink)
Rana Abboud's Avatar
Question 'Unfolding' complex mesh in Cinema 4D
Hi- I'm modelling a building that is conceptually generated by 'folding' and am trying to 'Unfold' this from the CAD data so it can be seamlessly constructed (CAM)
1) I've heard that there is a Rhino3D plug in that 'unfolds' complex models... does anyone have any experience with this, or know of a similar plug-in that exists for Cinema4D?
2) Does anyone have any tips on how to rationalise an arbitrary 3D mesh into modular component parts? I am using Cinema4D for the prelim 'form' at the moment, and the task of manually modelling facetted planes to generate the shape seems incredibly time-consuming! Is there a better way??
Any suggestions would be terrific and v. appreciated, thanks!
Rana Abboud is offline
Old February 5th, 2008   #2 (permalink)
Claudio Branch's Avatar
Default Re: 'Unfolding' complex mesh in Cinema 4D
Originally Posted by Rana Abboud View Post
does anyone have any experience with this...
...Does anyone have any tips on how to rationalise an arbitrary 3D mesh into modular component parts
In a previous life, I did alot of 3D sheet metal work using Pro/E. We would basically model up a part in it's formed or folded state and then use a "Flatten" command to create the appropriate flat pattern. Working backwards in essence.
If your base geometry can be imported into a program like Pro/E or Solidworks, then the design can be used as a skeleton to model the appropriate formed parts and flat-patterns that need to be made to build the design.
Know any parametric modelers with manufacturing experience?
Claudio Branch is offline
Old February 5th, 2008   #3 (permalink)
Thanks for the post Claudio-
Nope - don't yet know modeler/manufacturers here in Sydney, but will definitely try to find them, and look into Solidworks in the meantime.
Old February 6th, 2008   #4 (permalink)
STRAT's Avatar
Wales
can we look to post in the correct forum next time please?
STRAT is offline
Old February 6th, 2008   #5 (permalink)
shaneis's Avatar
Why not contact an Industrial Designer or Rapid Prototyping specialist.
Haven't heard of C4D being used with CAM equipment, but a couple of manufacturers do include Rhino (or plug-in to Rhino) with their accompanying software packages.
shaneis is offline
Old February 6th, 2008   #6 (permalink)
He's a first-timer....
Rana,
I recommend that you look around for companies that are doing sheet-metal fabrication, send them your design and ask for a quote.
Old February 6th, 2008   #7 (permalink)
Egypt  Send a message via MSN to IHAB Send a message via Yahoo to IHAB
I think that "she's"...?
[FONT='Times New Roman','serif']http://www.rasoulallah.net/[/font]
IHAB is offline
Old February 7th, 2008   #8 (permalink)
I think you're right....
If so, my apologies Rana.
Old February 25th, 2008   #9 (permalink)
nicnic's Avatar
Form Z has a great unfold tool, I used it to make physical models from 3d ones, its puts on tabs / fold lines etc to glue. Also a very interesting generative tool for messing around with.
nicnic is offline
Old March 12th, 2008   #10 (permalink)
Thanks heaps for the tips... and apologies on posting in wrong forum! (Have now learnt, and migrated to 'Rhino' area of Forum).
Will try sheet metal fabricators next. Thanks again.
make poly and mesh panels (including shortcuts) identical DavidR 3ds Max Wish List 3 January 2nd, 2008 10:06 AM
3DS Max or Cinema 4D? Ola General Discussions 15 September 3rd, 2007 03:42 PM
Mesh Displacement Tool marcdevon General Discussions 2 December 29th, 2005 08:40 PM
Kinda dumb mesh question AJLynn Cinema 4D 6 November 3rd, 2005 04:57 PM
editable mesh or editable poly? watersage Autodesk VIZ 0 September 20th, 2004 07:46 PM
