Name: Mark Johnson |
Question #1
Is there a syntax I can use to allow lightScape to run an animation of my model via window command prompt. like I do for my radiosity processing and image processing instead of opening lightscape and running it from there. Question #2 Does anybody know how I can add music to a Divix formatted animation? --------------------
love |
#2 (permalink) | ||
I usually write the commands into a batch file so I can save and adjust my commands, also useful to render a series of camera moves one after the other while you sip cool drinks by the pool. Check the manual or the help file for the full syntax. Another option is to install LSnet, even if you only have one CPU. It puts a front-end on the command-line utilities, making them easier to use but still taking advantage of the speed of not loading the UI. Quote:
