Old February 11th, 2008   #1 (permalink)
Name: Anwar Fardullah
Singapore
Default gamma settings for max 2008 and photoshop
Hi guys,
i have read a few posts on this issue about the mr photographic exposure control and the gamma settings. correct me if i'm wrong, the max08 user reference guide stated that to achieve a balance settings of max's gamma settings is to use a value of 1.8 for the gamma value, as for bitmap, values of both 1.8 for both Input and Output, this is based on my monitor settings
but on the other hand, it also stated to use a value of 2.2 for the gamma value, and for both bitmap input and output gamma when used with photoshop.
my testings shows the best value is gamma value of 1.8, and both 1.8 for bitmap input and output value, but not sure about photoshop settings. i use the srgb 2.1 something like that...as stated in the user guide.
so what is the best comprimising values for both application?
mesht is offline
Old February 11th, 2008   #2 (permalink)
Justin Hunt's Avatar
Default Re: gamma settings for max 2008 and photoshop
I have been using gamma 2.2 for both max and photoshop. I did use 1.8 for a while but found I was having to brighten up some more in photoshop.
Try both for a while and see which suits you better
JHV
Justin Hunt is offline
Old February 11th, 2008   #3 (permalink)
Wink Re: gamma settings for max 2008 and photoshop
Hi
I went to the Autodesk Design Visualisation roadshow in london last week and they adivised a setting of 2.2 for the gamma
BobM
BobM is offline
Old February 11th, 2008   #4 (permalink)
Singapore
thanks for the tips
maybe i'll try value of 2.2 and see if it's acceptable. tried 1.8 and yes, it seems a bit too dark
mesht is offline
