Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old February 17th, 2008   #1 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default 3dsMax multi/sub-object script?
anyone have a good script or heard of a good script for manipulating the number assignments on multi/sub-object materials, and the corresponding objects in an editable poly?
...i have several cars that are collapsed to editable poly's with multi/sub-object materials. unfortunately the corresponding elements of the cars do not match on the numbering system from object to object.
meaning, if the tires are in the number 6 slot of the matial on the first car, they might be in the number 10 slot on the next car. i want to unify the materials as much as possible, but doing it by hand will prove to be tedious.
travis schmiesing
crazy homeless guy is offline
Old February 19th, 2008   #2 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
Default Re: 3dsMax multi/sub-object script?
I dont think that would be difficult to make, but i'm shot for 'free' time for the week.. I sort of picture it as a material ID 'swap' same as if you drag/drop materials.. could be as easy as two number entry slots and a 'swap' button.. I dont know offhand how to do the material swap itself though, so you may end up doing it as a two step thing.
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Script for incrementally moving camera around object Brute Guy General Discussions 5 January 16th, 2008 09:27 PM
script: Random material ID quizzy Scripts 2 April 22nd, 2006 03:04 AM
script: Object cycler. quizzy Scripts 0 March 13th, 2006 07:59 AM
why is one object not one object RAYMOND Autodesk VIZ 4 November 7th, 2005 12:00 PM
