Autodesk VIZ Autodesk VIZ
Old February 19th, 2008   #1 (permalink)
Ireland
Default Xref Objects in Viz 2008
Hi all, I'm having lots of trouble with Xref objects in Viz 2008. a lot of the time when I add an Xref object, I cannot load up the scene again,and when I try to render it usually crashes.
I never had this problem with Viz 2005.
Hobo Monstrocity is offline
objects don't display in max 2008? Brian Cassil 3ds Max 6 February 4th, 2008 01:28 PM
Instanced Xref scenes klaas nienhuis 3ds Max Wish List 5 December 21st, 2007 08:37 AM
changing xref objects notamondayfan 3ds Max 2 February 28th, 2007 07:22 AM
xref objects with lights dvmorris Autodesk VIZ 1 June 12th, 2006 02:20 AM
Removing missing XREF Objects bwilson 3ds Max 0 November 2nd, 2004 02:25 PM
