| Finished Work Post your final 3D Art works here to be critiqued by other board members. |
Name: Jeroen Prins |
Hi Kittu,
Nice lighting! Its a good start but this isn't your final image right? If it is; - you need higher irradiance map settings and AA settings, - You can see the vertical glass lines but not the horizontal? maybe add some detail here. - I think you can improve the bump off the wood which looks like it is not every where. - If i look at the photo it looks like the bottom off the window must lower then the floor. Other then that, there is some post work to do (levels, contrast). Good luck hope it helps a bit! |
| Run Down Residence Wip | cjlopez4 | Maxwell Render | 2 | July 25th, 2007 02:19 PM |
| [3ds max] Parra Residence | cmeraz3d | Work in Progress (WIP) | 8 | June 11th, 2007 12:34 PM |
| residence exteriors and interiors | viju | Work in Progress (WIP) | 1 | August 31st, 2006 03:37 AM |
| residence : exteriors | kippu | Finished Work | 8 | August 8th, 2006 06:18 AM |
| residence; feedback please | celticdog | Work in Progress (WIP) | 17 | January 26th, 2005 04:26 AM |
