Old February 24th, 2008   #11 (permalink)
CreativeElixir's Avatar
Default Re: Need help witn animation problem
Still trying to understand the adjust your velocity comment. I am posting a screen cap of my adjustment on the motion tab.
CreativeElixir is offline
Old February 24th, 2008   #12 (permalink)
Also, I set the keyframe position to 65" on the z axis for eye level view in path tab. Is this correct?
Old February 25th, 2008   #13 (permalink)
Attach the .lp file if its not a problem
p.s. I see that your playback end time is 1.6 sec! Maybe you want to put it to something higher, like 30 sec.
Beeeee!
del82 is offline
Old February 25th, 2008   #14 (permalink)
my lp file is pretty big and too large to post on forum. Can post to private ftp site and have you download from there.
Can you send me your email address and I will email you ftp site info to down load file from.
Thanks.
Old February 25th, 2008   #15 (permalink)
Just wanted to give a big thanks to Del82 for all your help with getting my issue resolved. If you are ever in the Atlanta, GA area let me know cause I owe you a few beers!!!!!!
Also, thanks to the forum for having such a great resource available to the Lightscape loyalists out there that still exist and still use such a great product!!!
Cheers,
Kevin
noise problem in interior animation.. shikodesign2000 VRay Render 14 August 16th, 2007 08:31 AM
Problem in vray animation.. shikodesign2000 VRay Render 4 August 5th, 2007 03:53 PM
Vray animation render problem field3d VRay Render 4 January 15th, 2007 11:34 PM
IRMap animation problem aligrafix VRay Render 18 June 2nd, 2006 03:19 AM
Viz4 Animation Jitter/Flicker Problem jbennett134 Autodesk VIZ 6 March 25th, 2004 08:39 AM
