Old February 22nd, 2008   #1 (permalink)
CreativeElixir's Avatar
Unhappy Need help witn animation problem
I am trying to set up an animation in LS 3.2. I go thru the process of getting the camera path set up and adjusted. Then I try to go to the playback screen to preview the path and it will only run thru thr first segment of the path. It is like it see's the segments on the path as all disconnected even though they aren't. Am I missing something?
Desperate for any assistance available. You can also email me directly at creativeelixir@gmail.com
Thanks in advance!!!
CreativeElixir is offline
Old February 23rd, 2008   #2 (permalink)
Default Re: Need help witn animation problem
Check that the playback time doesnt end at 1,00 sec
Beeeee!
del82 is offline
Old February 23rd, 2008   #3 (permalink)
I did and it does say 1 minute, but if I try to change the number in the playback end time to anything over 1 and click on the apply button, it just changes back to 1.
I was thinking that somehow it is not seeing the camera key frames beyond the first segment. I have even tried testing multi point keyframes and get the same behavior.
BTW.....thanks for the help!!!!
Old February 23rd, 2008   #4 (permalink)
attaching scren cap of playback dialog box.
Old February 23rd, 2008   #5 (permalink)
Post an image of the "motion" tab!
Beeeee!
del82 is offline
Old February 23rd, 2008   #6 (permalink)
Attached are screenshots of the motion and path tab.
Should there not be more points on the motion tab? Am I missing something?
This is my first attempt at doing an animation in Lightscape so excuse my ignorance if I missed a step in the lightscape animation process.
Let me know if I missed a set. Pretty much followed lightscape animation tutorial, but got stuck when I saw that the playback was only running the very first segment.
Thanks.
Old February 24th, 2008   #7 (permalink)
Can you attach the animation path file.
Beeeee!
del82 is offline
Old February 24th, 2008   #8 (permalink)
my test file is attached.
File Type: zip test anime.zip (558 Bytes, 1 views)
Old February 24th, 2008   #9 (permalink)
Drag the red dot in the "edit mode" and adjust the velocity of your path.
Beeeee!
del82 is offline
Old February 24th, 2008   #10 (permalink)
Is there suppose to be a red dot on this grid for each keyframe point on the path window?
noise problem in interior animation.. shikodesign2000 VRay Render 14 August 16th, 2007 08:31 AM
Problem in vray animation.. shikodesign2000 VRay Render 4 August 5th, 2007 03:53 PM
Vray animation render problem field3d VRay Render 4 January 15th, 2007 11:34 PM
IRMap animation problem aligrafix VRay Render 18 June 2nd, 2006 03:19 AM
Viz4 Animation Jitter/Flicker Problem jbennett134 Autodesk VIZ 6 March 25th, 2004 08:39 AM
