Old February 25th, 2008   #1 (permalink)
Invalid User Profile
Default Data in Vault System
We have about 200 GB worth of data in our Vault system– most files are stored as only one version. Our current backup procedure takes more than 4 hours to perform.
Since we are planning to add one more location in our organization, the size of the file store will probably double or triple in next two or three months. With the anticipated growth, the backups will take even longer. Is there a way to implement any backup procedure?
katiekafs9 is offline
Old March 2nd, 2008   #2 (permalink)
Default Re: Data in Vault System
You can mirror network stations so that anything on one is on the other too. This basically happens with real time backup. Since my IT guys work on it, no idea how it works.
andrew4wan is offline
Old March 6th, 2008   #3 (permalink)
A faster hardware could help. I would also recommend to use the –DBSC switch in the ADMSConsole line to exclude the standard content libraries from the backup process. Or you can use standard system (non-Autodesk) backup methods employing incremental/diffrential methods -- just make sure you stop your ADMS for such backup process.
damienrange is offline
Mental Ray/Image Based Lighting & the Daylight System? Brad_S Mental Ray 4 January 30th, 2008 03:13 PM
Purchasing advice requested Jeff's Friend Hardware and Technical Discusions 25 September 7th, 2003 06:12 PM
Hyper-threading and 3ds max system, conundrum, confusion, Please Help ! serious Hardware and Technical Discusions 8 February 11th, 2003 01:34 PM
