Old February 28th, 2008   #1 (permalink)
Sweden
Default Disabling shadows for "mr prim" hair?
I'm doing a lawn made from Hair and fur, and to speed things up I would like to disable shadow casting for the grass and only make the grass receive shadows from other objects.
Going to the growth object's properties and unchecking Receive shadows doesn't help... is there another way of disabling shadows?
I'm lighting the exterior scene with a daylight system, so I can't use Exclude for the sun (?)
Robert
architect/visualiser
i2 STUDIOS, Sweden
http://www.i2studios.com
robkar97 is offline
Old February 28th, 2008   #2 (permalink)
South Africa
Default Re: Disabling shadows for "mr prim" hair?
sellect the grass object, right click>object properties switch off cast shadows there
xeunox is offline
Old February 28th, 2008   #3 (permalink)
Sweden
That's the problem... it doesn't work :-( I think it does when using "buffer" hairs, but not for "mr prim"... Only the growth object (a simple plane) stops casting shadows.
Similarly, turning off Renderable for the growth object leaves the hair unaffected (it still renders)
i2 STUDIOS, Sweden
robkar97 is offline
MR & shadows weird problem isopropanol Other 3rd Party Renderers 2 April 14th, 2004 08:05 AM
