Hi guys another query that i hope people can help with
i have a fairly decent light setup for an exterior that i am practising with however, i want to keep this light solution but use a sky bitmap in the background so i have clouds etc. the scene is setup with a daylight system mrsun mrsky mrphysicalsky photgraphic exposure i believe you can place bitmaps in the haze slot of the mrphysical sky but this doesn't seem to work i have attached the original render and below is a link to the sky texture i am using http://mpan3.homeip.net/content/reso...ky/dayfair.jpg |
Name: Håkan Andersson |
If you want to put the sky bitmap in the haze slot, read this. You need to turn it's output up to around 10-ish.
If you just want to use it as an actual background image, well, then just use it as a normal spherical environment in the environment map (remove the physical sky completely), or, if you only want it as a background image, use it in the "background" slot of the physical sky itself. Either way, you should also read this to understand that you need to turn it's output level up approximately 2500,0 /Z
mentalraytips.blogspot.com - mr Zap Andersson - a completely mental shader guy |
Name: Francisco Penaloza |
puting a sky image with the Mr Combo sun and sky it is a very pain in the but, but there is some work around, normally I put the sky in post but if you want an animation I rather put a dome sky and make a work around that Jeff Patton explain here.
If you still want to use the image map in the mrsky you have to pull way up the RBG values of the image, remember that Mr Sun and sky use "a lot" of illumination and with the photographic exposure it is more evident, so your image must have the same "output" values |
#4 (permalink) | |
glade to see you around here Master!! |
ok in the image i posted i had the settings as described, i then made one change and that was putting the bitmap in the haze slot, i sat the haze value to 1 and the output level on the bitmap to 10, the bitmap was only just visible but it was also not projecting the true colours it did when viewed in a normal windows picture viewer????
i then tried with a skydome and just a mrsun, everything works but i had to select unitless on the photgraphic exposure and up the value of that otherwise the scene rendered black, and also the mrsun was having no effect even tho i had used ray switchers on the mental ray material etc, with me selecting unitless on the exposure control would i then need to up the intensity of the mrsun to get it to have an impact on the scene? thanks for the help so far guys |
also i am having difficulty getting my head around altering the settings of the daylight system so that the sun intensity, position etc matches that of the sky bitmap, if i use a sunset bitmap, would i need to reduce intensity (mulitplier) of sun and sky and obviously the time, and would i need to alter exposure control settings to accommodate
how do you guys go about this?? eventually i want to render out various images of the same building at different times of the day but i want to use sky images as the sky rather than the physical sky. i also want it to look as photorealistic as possible. what are your general workflows for this kind of process? |
#8 (permalink) | ||||
It's not true volumetrics, of course, but it's pretty nice because it follows the color over time-of-day, and gives you the visible sun disk for free. Quote:
You have two options with a "sky background photo" a) Keep using the mr Sky as lightsource OR b) Use the "Skylight" as sky lightsource, set to "Use scene environment" mode, multipleir 1.0 In either case you must make sure the physical intensity of your "background photo" matches that of a sky, which you by turning up your sky bitmap's "Ouput Level" - or - as you tried - by playing with the "physical scale". My blog is shock-full of explanations on this topic. Quote:
/Z
#9 (permalink) | |
Also, by the way, I just attended a lecture by an architectural photographer. They say they avoid clouds at all cost, and if one sneaks into an image, they paint it out in photshop... Ain't the world fun? /Z
thanks a lot for your help zap
when i mentioned using a rayswitcher on the skydome, i was following a workaround described by jeff patton, where he talks about applying a bitmap to half a sphere that encloses the scene. it can be found on his blog. i eventually got it to work all i was worried about was trying to match the daylight system to that of the different bitmaps i had for different times of the day. but with your help i am nearly there. i am also looking for a best practice when it comes to gamma settings for p/graphic exposure and whether they should be changed when using logarithmic exposure. the reason for this is that when i do make a render using a sky bitmap, the colour of the bitmap in the render is not the same as the original bitmap file????? |
| Mental Ray/Image Based Lighting & the Daylight System? | Brad_S | Mental Ray | 4 | January 30th, 2008 04:13 PM |
| VRAY sun/sky system and bitmap in enviro slot | Horhe | VRay Render | 2 | January 9th, 2007 11:55 PM |
| daylight system, radiosity and interior space | ninghai | 3ds Max | 7 | January 8th, 2007 01:32 PM |
| Daylight System Washed Out | ivanjay | Autodesk VIZ | 9 | February 17th, 2005 02:23 PM |
| Daylight system & Interior | ninghai | 3ds Max | 17 | September 30th, 2004 04:42 PM |
