Old February 29th, 2008   #21 (permalink)
South Africa
Default Re: i am loosing it...
try calculating fg on draft, on a a4 of 72dpi, and then on 300dpi, using a semi complex to complex scene and you'll see why. i do it for render speed, but also so keep the correct size of the fg solution on a larger scale with very little change in quality
xeunox is offline
Old February 29th, 2008   #22 (permalink)
Ireland
I understand that Pieter but maybe this is where it is going wrong for you?
Cheers
Tommy Burns is offline
Old February 29th, 2008   #23 (permalink)
South Africa
subset of scene shader, i've looked in the render dialog in the lens shader slot, but i can't find it there, also can't find the topic on jeff's blog.
xeunox is offline
Old February 29th, 2008   #24 (permalink)
Ireland
This is the tuorial here http://www.vizdepot.com/forums/showp...90&postcount=8
But first
You also have to unlock the proceural shader (subset of scene) in your ini file it is a hidden shader have a look here. http://www.lysator.liu.se/~zap/pd/unhide-max.html
It is well worth doing this there are lost of hidden shaders but this ones a gem
Enjoy!!
Old February 29th, 2008   #25 (permalink)
South Africa
final camera 1
xeunox is offline
Old February 29th, 2008   #26 (permalink)
South Africa
here we go again, cam 2.... delete both fg and gi calcs, changed the exposure to compensate for light changes, and recalculated the fg again, and its artifacting like the 1st image again...
i have now switched of both fg and gi and i'm just using the exposure controll to render out the image, its looking ok, but it has to do, cause my time is up... i will post as soon as it finishes
xeunox is offline
Old February 29th, 2008   #27 (permalink)
South Africa
ok well this makes no scence, i tried something, i moved the camera i used in scene 1, onto the position of cam 2, recalculated the fg, and its perfect?!?!?!?
xeunox is offline
Old February 29th, 2008   #28 (permalink)
Ireland
Well delete camera 2 and animate camera 1 for all your scenes and images
Old February 29th, 2008   #29 (permalink)
South Africa
giving up on me hey, i don't blame you with all my flaming
xeunox is offline
Old February 29th, 2008   #30 (permalink)
Justin Hunt's Avatar
You can render two different camera angles to the same FGM, as long as they are in different possisions. The photon map is view independant so you only need to calculate it once for both cameras, so long as the are no changes in the scene.
The grainyness could be down to either low AO samples or low reflection glossie samples.
One a side note check the scale of the people, they are huge.
JHV
Justin Hunt is offline
loosing a file sima-b 3ds Max 3 January 2nd, 2008 08:38 PM
loosing the small radius when inisialising Lee Taylor Lightscape 0 August 30th, 2003 03:58 PM
LOOSING linkage between windows and walls VIZ4 chadsmith Autodesk VIZ 3 March 31st, 2003 06:00 AM
