Old February 29th, 2008   #1 (permalink)
AJLynn's Avatar
Default This is odd...
With apologies to Jeff Patton, see attachments (Max08 file). I was messing around with an oversimplified version of a space I'm working on to experiment with some settings and exposure control, and I wanted to bounce a caustic off the floor. Used the Satin Varnished Wood preset, and started getting this sort of crap:
361053: no photons stored after emitting 1000000 photons from light "Sun01|Light" (tag b93): canceling emission job
RCGI 0.6 warn 362004: no photons stored after emitting 10000 photons from light "Sun01|Light" (tag b93)
and a very slow photon map calculation with no apparent caustics.
Long story short, after some experimenting, for different values of the reflection glossiness on the wood floor:
0.51 and over produce the expected effect
0.5 and under produce the error
WTH is so special about glossiness=0.5? I would think that any reflection glossiness should be able to produce a caustic of whatever blurriness.
AJLynn is offline
Old March 1st, 2008   #2 (permalink)
Sweden
Default Re: This is odd...
Have you tried enabling the photon radius setting for the sun? Focus the beam of photons on the window. However, that does not explain your problem. Have you set the geometry to receive/generate caustics where necessary?
Robert
architect/visualiser
i2 STUDIOS, Sweden
http://www.i2studios.com
robkar97 is offline
Old March 3rd, 2008   #3 (permalink)
MasterZap's Avatar
Name: Håkan Andersson
Sweden
Correct; this is by design (although you could question the design )
Photons either reflect "glossily" or "specularly". Only "specular" photons contribute to caustics, only "diffuse" and "glossy" photons contribute to global illumination.
The A&D material treats any glossiness above 0.5 as "specular" for photons, and anything less as "glossy". Hence, it will not propagate caustics for glossiness 0.5 r less.
/Z
MasterZap is offline
Old March 3rd, 2008   #4 (permalink)
AJLynn's Avatar
Thanks for clearing that up.
AJLynn is offline
Odd reflections tbny 3ds Max 1 April 11th, 2007 11:14 AM
Odd Speckling. Help? TheGrandmaster1 VRay Render 7 November 14th, 2006 10:43 AM
Odd glow... Ky Lane VRay Render 4 August 29th, 2006 08:30 AM
Odd render problems leed Cinema 4D 11 November 6th, 2005 05:13 AM
