#13 (permalink) |
thats really really good mate, congrats,
but what is the blur hiding???? and any hints or tips on how the interior/exterior lighting setups were i can never get my photometric lights to look like that (going back to my original problem - does the fact the light portals are behind glass have much effect on how blown out it will be "reflections maybe?) |
#14 (permalink) |
The blur is hiding some identifying markings, of course - you're not supposed to know exactly what it is.
The lighting setup was... hang on, maybe I still have this in a file I can find... damn, this is so crude it's actually embarrassing... The sun has a multiplier of 0.03, sky is 0.05, camera is target with clipping and there's exposure control with EV=9. The track lights are from the internet, ERCO.73200.023.142 with the corresponding IES file and in Light Lister their dimmer is at 1200. The sun has photon targeting turned on and its GI Photons are set to 100 under the mental ray Indirect Illumination tab. GI is turned on and the average photons per light is 1500. FG is set to draft with multiplier at 1.5 and there are sky portals with default settings. All the materials are A&D and most have some kind of glossy reflection. Basically I'm throwing more of my computer's time at the problem than my own - I figure I could have optimized it more but I didn't feel like it. |
#16 (permalink) |
When you use GI+FG you don't need your settings for either to be so high. And the exterior looks sunny because those are the sun/sky settings appropriate to my camera's exposure - basically I had perviously done another render in the interior where the sun/sky were at 1.0 (the outside was blown out but that was ok) and I had made the adjustments in the exposure control and interior light dimmers to get everything looking nice. Then when I wanted the section (this is design process stuff, in an architecture firm, and it was an impromptu thing) I adjusted the sun to balance it to the interior lights then made some tweaks in the exposure settings, and Photoshopped the levels to make it what I wanted. In the Photoshop file the top layer is Levels set to 5/1.2/235.
I did say it was crude... |
#17 (permalink) |
problem with zap's solution to my initial question
when you change the transparency colour, you still can't see the environment through the sky portal, it is now just black ?? i have a panoramic bitmap in my environement slot but nothing is showing. The blown out effect is fixed however so and aj it maybe crude, but these are tips that help people like me out when we struggle for ages to get the result that i want, we may not think to do it like that although it works for what we want |
#18 (permalink) |
Name: Justin Hunt |
sounds like you have turned the transparency down too much.
Here is a basic test , two portals one with transparency one without, mrsun and sky, photographic exposure @ ev 12 , GI and FG Portal transparency colour value @ 1 (white), 0.5 (grey) and 0 (black) and last one has a pink colour Notice how the light doesnt change, only the intensity of the mrphysical sky. Notice how the pink tinted the sky but not the lighting Notice that the portal lights dont quite fit in the window (Im lazy) and how the sky "outside" the portal is still blown out jhv Last edited by Justin Hunt; March 6th, 2008 at 06:30 PM. |
| Adding realistic clouds to sky or rendering | Timothy Saunders | 2D/3D Tutorials | 10 | August 18th, 2008 07:15 PM |
| Vray physical sky question | Tommy L | VRay Render | 4 | January 31st, 2008 07:12 AM |
| animated clouds | pauldoherty | Cinema 4D | 34 | October 17th, 2006 03:04 AM |
| to sky or not to sky | crazy homeless guy | Work in Progress (WIP) | 9 | October 23rd, 2005 03:39 AM |
| CIE standard overcast sky sim | Glen - UK | Lightscape | 9 | March 29th, 2005 07:29 PM |
